I'm a new member here, and would like to ask for advises in building and running the pulsejet.
I'm planning to build a valveless pulsejet for research in Singapore. Rather than using it for thrust, the company I worked for wanted to see if the exhaust gas can be applied for drying. The thing is, this is the very first time we're building something like this, and I would like to hear some advises on these issues:
1. Design
For the initial experiments, I want to build a very simple design. Is it possible to run a 'straight' type of valveless pulsejet?
Basically, I got the dimensions from the Pulsejet Calculator v1.4 (for a 5 kg thrust), but without the valves, and will be using a sparkplug for starting.
Also, I plan to use propane for fuel.
Will it work? I understand that in the end we still need to 'play around with it' to get it to run. But of course I hope I don't miss out any vital elements
2. Safety
I have read in this forum that propane itself is not combustible without air, thus we won't have any 'flash-back'. Still, my supervisors are very concerned about the safety of running a pulsejet - they're worried about the possibility of an explosion, fire hazards, loud noise, etc.
So, they propose to build something like a protective hood/encasement for it.
Has anybody encountered any accidents with the pulsejet? Or, has anybody build this kind of encasement before?
Ok, I think that's all for now from me..sorry for the proper lack of introduction. The research is still in a preliminary stages, and I don't think there is anybody working on a pulsejet in Singapore..thus I turn to this forum
Thanks!!
Regards,
Toby
