I stuck this in the ramjet forum b/c I fear the ramjet's functionality over the rocket's.
Have the rocket shoot down the ramjet uninterupted would be a necessity, gotta keep rocket thrust up!!
things considered:
*Safety- The liquid fuel cant set the rocket ablaze or endanger those on the ground
*Ejection- With almost no real way of knowing how long the ramjet would burn I think I figured out an ejection method that is safe
*Ignition- The ramjet's fuel would be ignited by the rocket and not rely on any special timing, this is all built into the design
*Fueling- Much safety has been built into the general design so the rocket isnt spraying flaming fuel as it plummets to earth
Basic design:
Rocket nozzle points down the intake of the ramjet, creating a venturi effect [ramjet is ducted]. So the rocket exhaust helps get things going, it also ignites the fuel. Maybe a nozzle like
Fuel is shot in by compressed air, it can only work when the rocket is pointing straight up; if the rocket were to nose over the fuel tank would shoot out its compressed air and instantly stop spitting fuel [for safety].
Ejection would be achieved by a type of Mercury switch. Maybe a 4 inch pvc pipe with a bit of saltwater in it. 2 contacts in the top are activated when the rocket noses over and set off the charge, proabably a compressed air charge though it adds weight it keeps any fire away form the fuel tanks.
Ignition of the rocket starts the fuel flow. Either by a "force of gravity" switch or the ignition charge wires are also in contact with a solenoid that will open the fuel lines.
I think the rocket itself can be kept pretty small, dont want it to be bogged down by a larger body of heavy materials.
If the ramjet doesnt light hopefully it makes a giant "propane torch" look and doesnt interfere with the rocket.
Got a 5 minute google sktchup pic I just drew, hopefully more to come!
Of course they are not finished, class tomorrow gotta sleep......
