Mike Everman wrote:
Two observations.
I think since you are using that curved surface as valve retainer, it should be grooved so you do not briefly make a vacuum between petal and outside wall. I do know that this can screw things up.
Also, the intake looks long to me. If the venturi intake was designed for a motor with a flat petal valve, then this intake section needs to be the same length from inlet to the average opening point of the valves. This length is critical, acoustically.
Hi Mike , thanks for the feedback , I tried shortening the inlet , didnt seem to make much difference , I didnt get to do the grooves yet , I understand the theory and it is a good point , but will take some "imagination" to do the grooves , ha
Graham C. Williams wrote:Hi Grim.
Will your motor run, without forced air, on Propane?
If it will then the pipe and valves are probably OK and you can be sure that it's the pressure drop across the fuel system that's the problem. If the motor runs on Propane, try sleeving down the induction cone. This will increase the air velocity and reduce the pressure over the injector resulting in a better draw of fuel and better atomisation.
I don't know anything about the acoustic length of the induction cone that Mike talks about but have seen these motors running without any cone at all, admittedly I think it was on Propane.
Looking at the design of the valve travel stops. It looks as if you have used the design of the outer shell to perform this function. Do you have too much valve travel would be my next question?
Nice motor.
Graham.
HI Graham ,
I tried propane briefly , but got loads of blowback from the inlet , I guess its one of them "feeling" things , just the right amount of air etc, Will try again, sleeving the inlet is on my list , we shall see
Correct, the wall of the transition is the valve stop , I done it like that in an attempt to provide better cooling for the valves , and you could well be right about the too much travel ,
Will keep experimenting , this engine is making good power, even as it is, I expect some good results once it is sorted , How many times you heard that one
Thanks guys , will keep you informed ,
