regenerative ramjet engine
Re: regenerative ramjet engine
Post by larry cottrill »
Viv wrote:I would question the ability of the recirculated exhaust gas to usefully add pressure or volume to the intake by entrainment
Pressure no, but volume is no problem -- that's what every ejector does. The resultant gas mix is slower than the driving jet stream, but MUCH denser and cooler. This should work well if you get it into the front end of a properly designed diffuser.
... any energy taken from the exhaust is lost to propulsion
Like, for instance, the energy taken up by a turbine? ;-)
... the losses will add up and negate the gains.
What makes this a given? What if the losses somewhat, but not quite, negate the gains? If you have that, the rest is just tuning.
The first "successful" gas turbine was the 1905 Armengaud-Lamale turbine, which was big enough to take months to build and weighed many tons. When they fired this baby up, they were able to get a whopping ONE PERCENT of the total combustion energy delivered to the shaft! If you were an investor, and these guys told you, "You know, this really proves that is IS practical -- the design just needs some more work to make it really good," what would you have said to that?
I would recommend Foa's book on propulsion as it covers these types of engine and other interesting types as well.
Yes, it is probably just my own ignorance that makes this look so great. NASA certainly didn't buy into my attempt at it:
http://www.cottrillcyclodyne.com/Cyclod ... ction.html
Post by Viv »
Hi Larry
All good points but I just don't think the maths add up in the right direction, mind you having said that there are a few around here who are convinced that if you can build one and get some noise out of it it obviously works and damn the detractors in shouting from the wings ;-)
Ghrey
Post by Ghrey »
I do not think it would work as drawn, It just seems like you would have to take to much from the back end to feed the front end.
But a very hot fuel or NO2 or both.
There is allot of may be here.
Will it maintain? Will it start to pulse? ( would that be bad ? )
Can it be built in a more aircraft friendly form?
It may just have to be built to know.
Life still complicated.
sockmonkey
Post by sockmonkey »
What if there were a set of vanes in the intake that caused the looped around exhaust to spin as it entered rather like a toilet flush?
Ghrey
Post by Ghrey »
sockmonkey; I am thinking drag. But ...
Ghrey wrote:I do not think it would work as drawn, It just seems like you would have to take to much from the back end to feed the front end.
What makes everybody think you have to take it from the back end?
Hint ... hint ...
See "Cyclodyne Revealed", coming up shortly.
Post by Viv »
Like a lot of other people here we are all dying to see how this gets answered ;-)
Ghrey
Post by Ghrey »
Just referring to the device in question, I long ago came up with a different geometry my self. Weight...
My current build uses head pressure to suck gas out the tail to increase blow.
