What Sam was saying is that the operating frequency is figurable from the length of the pot and considering the flame speed, which is constant, but the length is not, so a smaller one will have a higher frequency.steve wrote:so what you are saying is that even if I was to make a smaller version, the frequency wouldn't increase much because the flame speed remains constant?
several of you have used water jackets to cool reynst combustors. Will exess heat cause the engine to die if run too long without it? I have seen pictures of Mark's snorkeler glowing from heat and apparently still running so I don't know what to think.
I think that the smaller ones getting too hot kills them by boiling the meth too fast and the mix gets too rich. Big ones can cope with this, because within reason, the meth can't boil fast enough to make a large volume too rich. (so the theory goes).
