20 lb Thrust Pulse Jet Engine KIts
Rocket Man
Post by Rocket Man »
I am having some 20 lb thrust Pulse Jet Engines engine kits laser cut. Is anyone interested?
This is a one time thing. The more I buy the cheaper they are.
Auto Cad work is $300 minimum.
Set up and labor is $95 per hour with 1 hour minium.
Not sure what the price of metal is yet. I am having a few kits cut from mild steel then the rest cut from stainless steel.
There are still a few parts than need to be cut on the bandsaw.
There are about a dozen parts total per kit.
I am going to order 10 engine kits for myself I am hoping they don't cost me more than $100 each but I have to wait and see.
Buyer has to weld the parts together them self. Air intake welds to combustion chamber, cone welds to tale pipe and combustion chamber.
Engine is propane fuel injection for easy start and set to run on any liquid fuel you want.
Engine comes with 5 reed valves. You can have as many reed valves as you need.
Thrust is 20 lbs on gasoline, a little less thrust on propane, about 24 lb on kerosene/gasoline and about 28 lb on methanol.
Once i place my order it will be too late to change it. The more kits I buy at one time the cheaper they will be.
There is a design change so it will look a little different than this photo.
