To those of you that have built three or more good jets without really knowing how they work, there will be little for you to gain from this effort. But there is plenty that you could contribute. for example if I say something that goes against your experience , then the theory is wrong in that respect. When the theory disagrees with reality, then it is the theory the need to be chained.
In order to come up with this acoustic theory I have had a number of simplifications.
I have ignored subtleties such as end correction, just to keep the maths simple.
I have straightened the jets.
I have ignored the combustion chambers, assuming in stead that they are of one stranded diameter along there length.
I have assumed that the combustion takes place in a flat sheet across the jet, this this unrealistic but it gives a point for taking measurements from.
Finally and most importantly this is a purely acoustic theory.( and there for incompleat), It dose not include Kadenacy witch is very very very important to pulse jets. (if you have stick a wet rag in one of the intakes to get it to work, then you could probably do with some one working out a good simple theory of pulse jets.
I am going to take the position that the reason no one as come up with a really good theory of how a pulse jet works, is because there needs to be three!
Valved pulse jets are quatre wave oscillators, the theory of how they work is well established.
The first type of valveless pulse jet that I will look at are the forced anti node pulse jets, that is the; Escopette, Ecrevisse, Kentfield and Lockwood-Hiller. These can all be viewed as long tubes open at both ends.
The second type of valveless pulse jet are the forced node pulse jets, these include the; Thermojet, the Chinese, and the Logan. These can be viewed collectively as quarter wave oscillators with a tube stuck in there side.
Any way that is me set up for a fall!
The gauntlet has been throne down!
So may the contest be friendly and may the best side win?
