Supplier "Flexible stainless braided hose"
Post by Viv »
If your building a pressure jet then you may want to look at this supplier for a high temperature flexible braided stainless steel hose to decouple the fuel feed pipe from the heat exchanger to the supersonic nozzle, nozzle alignment problems are known to cause power loss problems in pressure jet engines
See the main thread in tools and construction topic viewtopic.php?f=7&t=5670
