Engine mounts by the way, what is your opinion about them? Should the engine be fixed to the frame or would a spring mounted engine survive the vibrations and bumps better?
Perhaps I should go all the way and get an inflatable love doll dressed up for the occation and use as a passenger/symmetrical fairing?Even grandma would wear a varm knä filt whenever grandpa squired her around!
PyroJoe: Thanks for the advice, I will have to give the braking some real thought so I won´t do something stupid. One good thing is that the track is long enough for the kick to slow down enough from air resistance so I can brake it with my feet once the engine is shut down, I´d rather slide a kilometer before it stops than hitting the brakes at 150+ km/h and risk that it goes into a spin/tips over.
