Hi Anders,
I think that with E85 you don't have to worry about carbonisation at all (unless you generate extra extreem high temperatures)
As stated by me (and challanged after) the carbon is a result of a cracking process.
The ethanol though is extremely stable due to the chemical composition and due tue the short "length" (only 2 carbons long). The gasoline (in E85) is also pretty stable. Mind that an anti knocking quality is also partly an anti cracking quality,since part of the knocking is caused by self combustion of cracking products of the original fuel.
In a diesel engine the cracking process and self combustion is meant to happen, not to fast though.
That's why diesel fuel contains mostly the "long" hydrocarbons while gasoline contains more "crossed" (more stable) hydrocarbons.
Hope you all can follow this fuzzy explanation
Fedde
