Time to test, put a sparkplug in it today, built my mini spark unit, fired the plug, added air, opened the gas and WHAM it went, almost blew the vice it was clamped in off the bench.
I thought, well, if a bang can do that, what happens when it runs, lotta bangs, and it should blow it off the bench ?
Needs a lot of air to run, but when its warm, it will run alone, and I got it to flameout today too. So I guess Im on the right track, and metiz, your right, Its a bit LOUD.
Will try to get the mixture right, kind of hard without a proper jet and an airbleed sys. to tune.
I was thinking, maybe a petrol jet with an airbleed, and try some regular from the gastation.
I just dont know how much vacuum is in the intake on the motor, and I would need to make a venturi for it too, as you want a low pressure area around the jet tube.
I will make the intake a bit larger, and make the venturi the same size the intake tube is now, so It wont get starved for air.
You adjust the amount of gas with the jet, and the emulsion tube hole size lets ya bleed air into the gas before it enters the intake, tunable sys. to try on this motor,
Dont know if anyone else has tried this, but it was just something that popped into the empty space on top of my shoulders today.
Turn on the spark, puff of air to pull the gas up the line, and it should run, if not, tune the jets and the airbleed. Simple. I will try this out, but first in an empty intake tube,
To check how the airbleed oxygenates the out coming gas mixture, Hope the reverse pulses dont push the gas (and fire) back up into the tank
Man, what a long POST.
