Odd Metal jars
Copper electrons
A pretty green flame for March 17. Or is the camera making a blue look green?
ROY G BIV
The flame was blue on my computers at work, so it must be some green translation problem with my computer. I noticed a few thin, faint, vertical lines off to the left of the flames, one was blue, the other yellow. Wow, I just watched it again and the flames are blue now! And I'm not even taking Viagra! ha I think my computer is learning how to read the format now.
I just put that in because I recall hearing about it's side effects and thinking that's quite an odd effect. Boxers who get hit in the head sometimes lose their color vision for a few days.
"Less common side effects that may occur are temporary changes in color vision (such as trouble telling the difference between blue and green objects or having a blue color tinge to them), eyes being more sensitive to light, or blurred vision."
http://www.genericviagra.org/
12" diameter at the base, 26" length/height. It cycles slowly for about 5 seconds bottom fed on gasoline. Building a inner nozzle to be attached to a access plate on the side of the CC. Doesn't ignite from the opening, drilled a 3/16" hole in the side 9" from the bottom. use the MAPP torch to ignite through the hole.
The propane fuel ring on the large draft engine is constantly catching fire, will need to change layout.
- improved.JPG (15.53 KiB) Viewed 36662 times
GRIM
Here is my pulseboiler
It is actually an old thermojet CC that has the original inlets cut off and welded closed,
It has an outer skin separated from the inner cc wall by about 8 mm ,
The inlet is only about 2” long and it has a a Pyro Joe draft style exhaust,
The fuel injector is a radial washer type ,
No sparkplug , no air start , just a match down the inlet
Here I am pumping water into the outer jacket with a small electric fuel pump,
just fun
just fun
- pulseboiler .wmv
- (1.86 MiB) Downloaded 7199 times
GRIM
Heres a video of the pulseboiler transition from blowlamping to resonant running,
As I slowly open the fuel valve, you can see the blue gas / air mix start to accumulate in the throat of the CC, and when it actually blocks the inlet there is an instant transition to resonant running, then as I turn the fuel down again it slips back in to the CC, faaascinating !!
- transition.wmv
- (1.86 MiB) Downloaded 7201 times
GRIM
Heres the 180 pulsejetboiler ,
180 tailpipe , longer inlet and injector although it runs great , I had to weld a sparkplug in, and it requires air to start,
It is much more fun in draft configuration,
- 180 boiler 2mb.wmv
- (1.88 MiB) Downloaded 7191 times
That boiler is great. The flame to cycling transition is interesting, I see it also from time to time. If a poor injector is used it will often have a tough transition from the blow torching to pulsing and it can be a battle. If you install the last 45's up higher (on the 180) you may be able to start airless. I plan to do the same next weekend.
I spent some time adjusting the tailpipe transition on mine. Ended up with a 27 degree tailcone transition and of course, that 90 had to go. It helped ease the fussy.
After the modifications, I was testing it with the 3 point injector and achieved the best runs ever for this engine. I tested some other types of stinger injectors, but that three point "kicked butt". I really am pleased with that injector.
It achieved the highest frequency with this size of chamber and orfice (that I have observed). A few times I thought it might go ahead and PJ with the orfice! It was close several times but couldn't make the transition. This led to another modification I will reveal in a few days.
Also included is some organ pipeing.
IMO the "sounding" frequency has no role to determine if a engine performs well. It doesn't matter the frequency a pipe will "hoot","Rijke tube" or "Organ Pipe" under a thermal load.
What counts is for the tailpipe to work as a inertial pump. A majority of tailpipe volume has to be displaced each cycle. True, this is only exhaust from the last cycle, but a fair amount needs to be displaced to make room in the CC for the next intake volume.
It becomes obvious, when the tailpipe is removed. Stand alone combustion chambers have a tough time creating the same pumping action as created by the tailpipe.
- medprop2.wmv
- (1.23 MiB) Downloaded 7138 times
- organflame_1.wmv
- (1.83 MiB) Downloaded 7121 times
- organ1.zip
- The draft pipe will "organ" until heated.
- (499.91 KiB) Downloaded 292 times
- DCFC0049.JPG (137.29 KiB) Viewed 36446 times
- organexh.wmv
- (851.98 KiB) Downloaded 7105 times
- fastprop_1.wmv
- (961.73 KiB) Downloaded 7121 times
Finished the inner nozzle on the big jar and welded it to the access plate. It is only cycling for a few seconds on gasoline or propane. No "PulseLove" yet.
EDIT: design note: Reynst may have used a flue pipe with the early "improved pot" designs.
Reynst: "Early in development, design included a flue to carry the exhaust gasses into the open. It was possible to seperate mixture and exhaust by setting up a pipe of the same diameter as the mouth of the chamber, at a little distance from it. The edge of the pipe was sharp."
- DCFC0050.JPG (150.61 KiB) Viewed 36450 times
- platenoz.JPG (69.71 KiB) Viewed 36452 times
The recent modification on the large draft engine was to add a 4" long section of pipe to the intake opening. It was aligned inside the opening and stitch welded in two spots for easy removal. This pushed it up into PJ range, it now locks in.
- DCFC0014_1.wmv
- (856.25 KiB) Downloaded 6998 times
- DCFC0015_1_1.wmv
- (1.67 MiB) Downloaded 6983 times
- DCFC0025.JPG (15.61 KiB) Viewed 36307 times
- DCFC0016.JPG (104.17 KiB) Viewed 36307 times
Here is a jar with a regenerator tube welded to the bottom. The regenerator is filled with SS wire mesh scrubbers. It is very muffled, sound is almost absent in the video. Lynyrd Skynyrd would say "turn it up".
- 04-03-08_1940.wmv
- (340.69 KiB) Downloaded 6993 times
- wregenerator.JPG (15.21 KiB) Viewed 36297 times
A side note on the large draft engine. Before adding the tail transition cone, the engine would run a bit rough. When the engine was warm on occasion it would flame out.
It only took a short time for the heated draft pipe to clear all the exhaust from the chamber. This left a fresh charge of air in the chamber, if fuel was also present, on relighting this made a severe blast. The strongest blast of any jetish thing observed to date. One time it had my ears ringing while wearing earplugs.
I think if a sparkplug could be installed and timed correctly, this type engine could make a slow cycle blast engine. At this time I have no use for this type of operation. Maybe in the future if a noise device is needed it may be developed.
After adding the cone transition, the strong blast is gone.
