Browns gas does anyone know how to create this in bulk?
I know it comes from electrolysis but how to create it is what I am looking
for.
I create the hydrogen but it takes so much to create the hydrogen
It is not worth the effort I have made my small car go from 25 mpg
To 35 mpg but that is not good enough using a single cell
I want to create browns gas and use the gas that comes off
It to fuel my car 100%
I once read a story of a race car that had no gas in it and
Had just a small amount of browns gas running to the carb
And it ran great
Thank you for your time.
Browns Gas
re: Browns Gas
Here are some links I find some time ago, because a wanted to make a welder, I decided not to build it because its to dangerous.
RhodesGas
Rhodes himself
patent
RhodesGas
Rhodes himself
patent
re: Browns Gas
browns gas is nothing more than the mix of hydrogen and oxygen from electrolosis.
theres some real fantasy stuff out there, dont waste your time on that.
By all means use hydrogen to run your car but use solar panels to run the electrolosis for you.
If you want quick cheap hydrogen at the expense of using aluminium foil and caustic soda then thats easy.
make up a reasonbly strong water and soda mix say 20 or 30:1 (water/soda) then drop bits of aluminium foil into it , it will fizz up and hey presto "hydrogen".
Just be careful with it cos it burns very rapidly, like TNT does!
Nick
Nick
