see running new type of pressure jet - methanol fuel
zono
Re: see running new type of pressure jet - methanol fuel
Post by zono » Sun Jun 28, 2020 4:08 pm
here is the video again, the old link of which no longer worked is obsolete.
The typical non-glowing flame of the methanol fuel is unfortunately hardly visible due to the glaring sunlight. At the end you can see them briefly.
You can see other effects quite well, such as the rocking fuel tube, which comes from the deformation of the very hot evaporator tube. on the left you can occasionally see the supersonic fuel vapor "blasting" into the engine.
https://youtu.be/pn556p5YKPs
engine details :
vaporizer coil
methanol vapor ejector (injector) , Temp. 400 - 600 degC
___________________________
zono - the thruster buster
zono
Post by zono » Sun Jun 28, 2020 4:40 pm
hints:
the unsteady combustion comes from the lack of pump pressure, formerly a bigger pump was applied, but I haven't already as powerful pump.
note : methanol vapor saturation pressure at 250 degC is about 100 bar !! And my little toy-pump in this video achieves just 8 - 12 bar.
zono
Post by zono » Sat Jul 04, 2020 11:01 am
some meterings of the i-jet (ejector ramjet)
zono
Post by zono » Sat Jul 04, 2020 12:35 pm
insulated shroud and combustion chamber , inside view of combustion chamber, vaporizer coil and flameholder
flameholder edge and flameholder face marked-up yellow and red arrow:
creon2011
Post by creon2011 » Mon Feb 08, 2021 7:52 pm
that is really sweet work. do you have an update for us? would love to know more! Been thinking about methanol fuel as well!
