Al, I don't think you're going to have much of a problem with in-flight restart--if you design the ductwork properly for normal engine operation.Al Belli wrote:
I have several ideas on ground based starting systems, as well as having given some thought to in-flight re-starting. Ground based starting is simply a puff of air from an air tank, or from a blower. In flight re-starting will require some additional engineering for low weight and reliability.
Al Belli
These (valveless) engines respond to the increased pressure available from ram air recovery at higher speeds, with greater thrust output AND better fuel specifics. A properly designed (pressure-recovery) intake duct will ensure good airflow into and past the engine--and there will be plenty of air moving through the engine if a restart is necessary.
Acoustic Propulsion Concepts
