will this design work or not
hello everybody,i have made a simple pulsejet design to make use of the things found in my house and i thought of not to waste it..so iam going to make a simple pulsejet tomorrow..if you guys think this design is k,i will weld everything together..here is the design..
note: in this design can i push the intake pipe to some cm(4 or 5) into the cc or not..and in this design i use only one intake..After completing this design i will start making my big engine..please say me if i have to correct any dimension in my design,because iam eager to make a running model of my own design..thank you..
Re: will this design work or not
any reply from anyone..need a verification of design so that i could weld things together..
Sorry, no one here has a pulse jet calculator that makes a green light when you enter the right dimensions. This layout is the most forgiving of all, and will probably work fine, one you've got some proper flares at the ends of the tubes, and reliable fueling and spark.
thank you for your reply sir..i hope that it should run properly..going to make it..Mike Everman wrote:Sorry, no one here has a pulse jet calculator that makes a green light when you enter the right dimensions. This layout is the most forgiving of all, and will probably work fine, one you've got some proper flares at the ends of the tubes, and reliable fueling and spark.
here is the welded design,tomorrow the testing will be done..
http://imageshack.us/photo/my-images/20 ... 11177.jpg/
http://imageshack.us/photo/my-images/83 ... 11178.jpg/
http://imageshack.us/photo/my-images/82 ... 11179.jpg/
i tried to start the engine today used sparkler for starting the engine but unfortunately it was giving a continuous howling sound but didnt start dont know what to do..planned to use spark plug but my battery was little bulged at the front tested it didnt work..please say me is there anyother things available to use as ignition source..
You could use a torch to make a hotspot on the cc wall
hotspot means do you say me to make a redhot area over the cc right..metiz wrote:You could use a torch to make a hotspot on the cc wall
yes, like the size of a quarter or something like that.
Alternatively, you could put a torch at the end of the tailpipe and try to get the flame in the cc like that
I have just started building pj's and found that it is real simple to just light the injector at the intake, let it heat the cc for a moment and slowly apply air. What has worked best is when I cut my 1/4" OD copper injectors (2) with tin snips at a slight angle. It will look like there is no way that you will get enough propane through them but that just increases your pressure pulling in the right amount of air for starting. When I have it right it will explode when I put the torch to it and almost start up without adding air. Good luck! Be sure and post a video if you can.
thanks for the help everybody going to make some pulsejets after some time because i have got to join a univ for my higher studies..
decrease cc length to 12cm, decrease intake length to 9.5cm increase tailpipe to 65cm
here are the changes made in the engine as informed to me..didnt test it..
here are some pics..
my cc length is about 12.5cm and intake length is about 10cm and tail pipe length is 65cm..does the cc and intake length affect the performance of the engine..metiz wrote:decrease cc length to 12cm, decrease intake length to 9.5cm increase tailpipe to 65cm
i can hear a good growling sound when i keep the blower at the intake but doesnt start..so i have decided to use the full length(35inches) MS pipe which i bought earlier for this design..lets see what happens..
