larry cottrill wrote:
It's all in knowing how, of course -- and alas, there aren't many textbooks being written nowadays on analog computing.
One thing I don't get right offhand is the meaning of the + sign atop your "signal generator".
New books, are maybe non-existent. I have a couple, though of the old ones. As the new stuff replaces the old, people are throwing away the old. So the books, and the equipment could show up 'anywhere' if you are a 'rummager'. I picked up a Tektronix dual trace o'scope with manuals and its rack on wheels for $20US. It works.
The +tive sign is just a convention for the source; it shows which way the '
current' flows.
continuing ...
The above system is linear, so an analytical solution can be determined by hand. There is no need to program a numerical solution, neither digital nor analog. It took me about 2/3rds of a legal sheet of paper. I used what is known as the
Laplace Transform method.
Naturally, I 'punched' that 'bad boy' equation into a spreadsheet for a 'quick look see' of its predictions.
The result is a function of six variables. The proper way is probably to use '
dimensional analysis'. However, here is the first of three plots to give the reader an idea of what goes on when one ratio is varied, and the others held constant.
Notice:
- Again, here is the familiar 'bell-shaped' flow curve, that I showed you in my dynamic modeling of a strip valve thread.
- Observe the ratio of resistance to inertance for this model.
- Unfortunately, for this set of parameters, the flow continues out of the tube for the entire cycle. It never goes -tive therefore it never re-enters the tube.
- This may be good for an 'out flow' tube but certainly not for 'in-flow'.
