Hellmond P90
Hellmond P90
Im soon going to start fabricating a P90.
I notice on the CAD drawings from the hellmond team there seems to be 3 layers of petal valves each getting smaller in diameter, yet there is no elevation for each valve. Is this correct? 3 valves?
Re: Hellmond P90
Yes, they function like a leaf spring in car suspension systems.
Re: Hellmond P90
Great!! as if replacing a single valve every 10mins isnt enough. How much performance increase do you get from this?
Re: Hellmond P90
I have no idea, but some people in teh forum have been active in the Helmond project and will know better. I could be wrong, but the Helmond seems to be the most efficient pulsejet with valves ever built. If you go that far, you must expect complications.
Re: Hellmond P90
Hi Andrew, Bruno and others,
I built the PJ90 from the CAD plans, Andrew is talking about. It was the first pulsejet I made and when I announced that on the old Forum, a lot of people said that I could expect complications to. However, after some start attempts the PJ90 (..the one I made..) turned out to be a good starter. What is important is the amount of fuel you have to inject.
You can find pictures of it at my site:
http://pj-website.tripod.com/escopette/id12.html
Here you can see one of my start attempts. The big flame is a result of to much fuel so this is what you have to find out with testing the engine.
Pieter.
Pieter.
Re: Hellmond P90
Where do you guys get these plans for the pulsejet you're building? A website of download or something? Thank you very much
Grant
Grant
Re: Hellmond P90
Grant, look around. This website is not just a forum. There's heaps of other stuff. If you can't navigate your way out of the forum to the rest of the site, here's the homepage: www.pulse-jets.comdangerranger01 wrote:Where do you guys get these plans for the pulsejet you're building? A website of download or something? Thank you very much.
Re: Hellmond P90
Thank you, i am an idiot and didn't even know about that area. I have found a lot of blueprints under the pulsejet area but not this one. If you could tell of link me to it that would be awesome. Thanks again and sorry i'm stupid
Grant
Grant
Re: Hellmond P90
Try this one:dangerranger01 wrote:Thank you, i am an idiot and didn't even know about that area. I have found a lot of blueprints under the pulsejet area but not this one. If you could tell of link me to it that would be awesome. Thanks again and sorry i'm stupid
Grant
http://pulsejet.amtjets.com/technical_info.html
Re: Hellmond P90
No, you are not stupid. If you enter the site via the forum, it is not very obvious that there's this other stuff there, too.dangerranger01 wrote:Thank you, i am an idiot and didn't even know about that area. I have found a lot of blueprints under the pulsejet area but not this one. If you could tell of link me to it that would be awesome. Thanks again and sorry i'm stupid
Grant
Re: Hellmond P90
I've now got most of the engine build sussed. The part im not sure about is the intake venturi, how is this made? Two tubes, formed, then welded? Wouldnt this require special tooling?
I am building the engine to power a plane so aerodynamics and weight is crutial.
Re: Hellmond P90
andrew,
For the venturi I made/used a cone and a short piece of pipe that I hammered on a conical piece of metal to get the round venturi shape.
The material thickness of this pipe was 1.6mm and it was stainless steel 316L.
Pieter.
Pieter.
Re: Hellmond P90
Here is a picture of it.
Pieter.
Pieter.
- (125.55 KiB) Downloaded 1316 times
re: Hellmond P90
http://www.pulse-jets.com/phpbb2/viewto ... light=[url]
could it take a look to this post?
tanks
francisco cooreman[/url]
tanks
Re: Hellmond P90
spain .....
hola le escribo en español ya que me defiendo mas en español.
yo estoy fabricando actualmente ese pulsorreactor.
si lleva varias etapas de petalos.
ya pondre fotos.
ya pondre fotos.
