Holley Booster Venture on Dyna jets
nitro
Post by nitro »
I took my Bailey Fast jet & made a Booster Venture like Holley Carburetors use & put the head onto a Hobbyking pipe for a test run.I had to remove the main jet and just use the 2.5mm inside fuel line but it ran full power.This was just Methanol.The inside diameter is 30.5mm.I think Booster ventures are ideal for carbi Pulse Jets.My friends Pulse jet ran much the same but he has a 27mm inside diameter.Thrust was somewhere between 4.5lbs & 6lbs :wink:
