Back to Basic
Ghrey
Re: Back to Basic
Post by Ghrey » Mon Dec 07, 2009 6:36 am
And they only have;
Binaries
Platform Version Description
DOS 0.20.0b Compiler for DOS, including libraries, headers, {...}
Linux 0.20.0b Compiler for Linux-x86, including libraries, heade {...}
Linux 0.20.0b standalone Compiler for Linux-x86, including binaries, librar {...}
Windows 0.20.0b Compiler for Windows, including libraries, headers {...}
( Top )
Drat
Life still complicated.
WebPilot
Re: Back to Basic
Post by WebPilot » Mon Dec 07, 2009 8:28 pm
 Sounds like it's time to be especially nice to your significant other?
 Perhaps Santa Claus will bring you a new machine for Christmas - or at least a power supply if you can't cannibalize something from what your neighbors throw away or find something cheap at a flea market. Too bad you don't live closer to me - I've got lots of junk.
Ghrey
Re: Back to Basic
Post by Ghrey » Mon Dec 07, 2009 11:39 pm
Thw wife May be inclined to help. But I have a few carcasses buried about the place to try first.
It is a bad time of year to owe favors...
I really need an infusion of cash, stuff is just getting old, Just disposed of 4 printers, or rather prepared them for such.
Cheers.
WebPilot
Re: Back to Basic
Post by WebPilot » Fri Jan 15, 2010 2:44 am
Ghrey,
Did you get something working? or win the lottery?
Ghrey
Re: Back to Basic
Post by Ghrey » Fri Jan 15, 2010 7:31 am
Was stripping a full tower case the other day, the Matrox Stallion860 ( may have the number wrong... ) Mother board is past it, Twin 333mhz Pentium II's is just not useful any more....
Any way the power supply may work in the other machine.
Still pretty broke.
Got some santa cash so I have a new video device for recording...
No lotto win yet, I keep trying...
WebPilot
Re: Back to Basic
Post by WebPilot » Fri Jan 15, 2010 5:47 pm
It's good to hear you got a new toy for Christmas. I used a 400 MHz PII machine (and probably still could) for my audio recording and am learning to use my AMD 4050e for video.
This is just a heads up and you might want to get something up and running soon. I have two programs (BASIC) in mind and you're gonna miss some fun otherwise.
One of the progs is for play and the other is directly applicable to pjs. You won't need a brute of a machine for what I have in mind.
I did a lot of programming on that 400 MHz PII machine in BASIC, FORTRAN, and C . I also ran a variety of Linux programs, an AutoCAD clone, and a finite element code. It would be plenty.
Less is best.
BTW Do you recognize her?
Ghrey
Re: Back to Basic
Post by Ghrey » Sat Jan 16, 2010 10:33 am
Should have mentioned that it was no longer working...
WebPilot
Re: Back to Basic
Post by WebPilot » Sat Jan 16, 2010 5:50 pm
 Yours is a situation that would drive me 'stir crazy'. I've got some parts. What do you need?
Ghrey
Re: Back to Basic
Post by Ghrey » Sun Jan 17, 2010 8:48 am
Well it goes something like this;
CPU #2 lost it's cooling fan, a fault that caused a shutdown. So reluctantly I pulled #2 and limped along on just #1. Then something sad happened to HDD #2 a rather young 40gb Seagate. Recovered most of that. And was still looking for a fan, seemed like no one had one just then for that cartridge.... ( The MMX PII reminded of an atari game cartridge... ) So I put in a 40gb Hitachi drive and carried on. Then one day it just stopped. I could kinda get a boot and then it would freeze. The only successful run was with only a floppy drive hooked up, It will boot MS-DOS 3.3 from floppy. My surmise is that a critical buss component on the MB is no longer. Any thing hooked to the raid ( either actually ) controller and DEAD. The onboard IDEs Like wise. SCSI 1 or 2 ( set non Raid ) or 3 ( set non Raid ) like wise. PCI slot mounted HDD controller, be it IDE, DMA300, SCSI etc. forget it. I may have tried a few other things but it was 2/3 years ago.
Kinda Gave up after that...
I am only messing with it now because my replacement for it The Linux box I had just loaded Gambas on went down in the power supply, This was one of the afore mentioned "carcasses" that I have laying around, oh and look a power supply....
I am also prepping it's old case for a new board. Something with horse power, I hope, just have to turn in 300,000 or so cans for recycling...
I may get some time this monday to try a restart of Othello ( The linux box mentioned above ) But Opus ( the old Linux box is dead ).
Thanks for asking, I really have no Idea what I may need right now.
Unless you can send some time. Always short on that.
Cheers.
Ghrey
Re: Back to Basic
Post by Ghrey » Sun Jan 17, 2010 9:12 am
The picture reminds me of my high school sweetheart/girl friend, except for the fire arms. I suspect it is not her. :D
Re: Back to Basic
Post by PyroJoe » Mon Feb 08, 2010 9:06 pm
Here is a BASIC program I cobbled together for estimating top speed, time & distance. No guarantees on the accuracy, so far it appears to give some reasonable numbers.
Simon may rightfully pick up the code and swat me over the head with it. ha :D
Probably some glitches in it somewhere, but haven't found anything that is similar to compare.
Gives a second by second output
Code: Select all
10 CLS
20 Cd = 0
30 INPUT "Drag Coefficient Cd 0-1 "; Cd
40 Frontarea = 0
50 INPUT "Frontal Area of vehicle in sq. feet "; Frontarea
51 RR = 0
52 INPUT "Rolling Resistance pounds "; RR
53 'one slug = 32.174 pounds mass
60 LET slug = 32.174
70 weight = 0
80 INPUT "Total Weight in pounds "; weight
100 INPUT "Thrust of engine in pounds "; thrust
110 LET slugweight = weight / slug
120 LET accel = thrust / slugweight
130 PRINT "acceleration="; accel; "ft/sec^2"
140 LET time = 0
150 LET dragforce = 0
160 LET distfeet = 0
1000 LET velocity = (time * accel ^ 2) / accel
1010 LET mph = velocity / 1.46666
1020 LET distfeet = (velocity * velocity) / (2 * accel)
1030 LET miles = distfeet / 5280
1040 LET dragforce = (1 / 391 * Cd * Frontarea * mph ^ 2) + RR
1050 PRINT "seconds:"; time; "   Velocity mph="; mph; "   Drag&RR="; dragforce; "  distance in miles traveled="; miles
'(for Qbasic)1060 SLEEP (seconds0)
1070 LET time = time + 1
1080 IF thrust < dragforce GOTO 2000
1090 GOTO 1000
2000 END
Re: Back to Basic
Post by PyroJoe » Mon Feb 08, 2010 9:12 pm
An example run for a streamlined vehicle:
.12 for a reasonably slippery Cd.
4.5869 square feet for a frontal area
rolling resistance of 29 pounds
vehicle weight of 1500 pounds
Jet produces 100 pounds thrust
output of program:
acceleration=2.14493333ft/sec^2
seconds:0 Velocity mph=0 Drag&RR=29 distance in miles traveled=0
seconds:1 Velocity mph=1.46246119 Drag&RR=29.0030109 distance in miles traveled=0.20311869e-3
seconds:2 Velocity mph=2.92492239 Drag&RR=29.0120435 distance in miles traveled=0.81247475e-3
seconds:3 Velocity mph=4.38738358 Drag&RR=29.0270979 distance in miles traveled=0.18280682e-2
seconds:4 Velocity mph=5.84984477 Drag&RR=29.048174 distance in miles traveled=0.3249899e-2
seconds:5 Velocity mph=7.31230597 Drag&RR=29.0752718 distance in miles traveled=0.50779672e-2
seconds:6 Velocity mph=8.77476716 Drag&RR=29.1083914 distance in miles traveled=0.73122727e-2
seconds:7 Velocity mph=10.2372284 Drag&RR=29.1475328 distance in miles traveled=0.99528157e-2
seconds:8 Velocity mph=11.6996895 Drag&RR=29.1926959 distance in miles traveled=0.12999596e-1
seconds:9 Velocity mph=13.1621507 Drag&RR=29.2438807 distance in miles traveled=0.16452614e-1
seconds:10 Velocity mph=14.6246119 Drag&RR=29.3010873 distance in miles traveled=0.20311869e-1
seconds:11 Velocity mph=16.0870731 Drag&RR=29.3643157 distance in miles traveled=0.24577361e-1
seconds:12 Velocity mph=17.5495343 Drag&RR=29.4335657 distance in miles traveled=0.29249091e-1
seconds:13 Velocity mph=19.0119955 Drag&RR=29.5088376 distance in miles traveled=0.34327058e-1
seconds:14 Velocity mph=20.4744567 Drag&RR=29.5901311 distance in miles traveled=0.39811263e-1
seconds:15 Velocity mph=21.9369179 Drag&RR=29.6774465 distance in miles traveled=0.04570170
seconds:16 Velocity mph=23.3993791 Drag&RR=29.7707835 distance in miles traveled=0.51998384e-1
seconds:17 Velocity mph=24.8618403 Drag&RR=29.8701423 distance in miles traveled=0.05870130
seconds:18 Velocity mph=26.3243015 Drag&RR=29.9755229 distance in miles traveled=0.65810455e-1
seconds:19 Velocity mph=27.7867627 Drag&RR=30.0869252 distance in miles traveled=0.73325846e-1
seconds:20 Velocity mph=29.2492239 Drag&RR=30.2043493 distance in miles traveled=0.81247475e-1
seconds:21 Velocity mph=30.7116851 Drag&RR=30.3277951 distance in miles traveled=0.89575341e-1
seconds:22 Velocity mph=32.1741462 Drag&RR=30.4572626 distance in miles traveled=0.98309444e-1
seconds:23 Velocity mph=33.6366074 Drag&RR=30.5927519 distance in miles traveled=0.10744979
seconds:24 Velocity mph=35.0990686 Drag&RR=30.7342629 distance in miles traveled=0.11699636
seconds:25 Velocity mph=36.5615298 Drag&RR=30.8817957 distance in miles traveled=0.12694918
seconds:26 Velocity mph=38.023991 Drag&RR=31.0353503 distance in miles traveled=0.13730823
seconds:27 Velocity mph=39.4864522 Drag&RR=31.1949265 distance in miles traveled=0.14807352
seconds:28 Velocity mph=40.9489134 Drag&RR=31.3605246 distance in miles traveled=0.15924505
seconds:29 Velocity mph=42.4113746 Drag&RR=31.5321443 distance in miles traveled=0.17082282
seconds:30 Velocity mph=43.8738358 Drag&RR=31.7097859 distance in miles traveled=0.18280682
seconds:31 Velocity mph=45.336297 Drag&RR=31.8934491 distance in miles traveled=0.19519706
seconds:32 Velocity mph=46.7987582 Drag&RR=32.0831341 distance in miles traveled=0.20799354
seconds:33 Velocity mph=48.2612194 Drag&RR=32.2788409 distance in miles traveled=0.22119625
seconds:34 Velocity mph=49.7236806 Drag&RR=32.4805694 distance in miles traveled=0.2348052
seconds:35 Velocity mph=51.1861418 Drag&RR=32.6883196 distance in miles traveled=0.24882039
seconds:36 Velocity mph=52.6486029 Drag&RR=32.9020916 distance in miles traveled=0.26324182
seconds:37 Velocity mph=54.1110641 Drag&RR=33.1218854 distance in miles traveled=0.27806948
seconds:38 Velocity mph=55.5735253 Drag&RR=33.3477009 distance in miles traveled=0.29330338
seconds:39 Velocity mph=57.0359865 Drag&RR=33.5795381 distance in miles traveled=0.30894352
seconds:40 Velocity mph=58.4984477 Drag&RR=33.8173971 distance in miles traveled=0.3249899
seconds:41 Velocity mph=59.9609089 Drag&RR=34.0612778 distance in miles traveled=0.34144251
seconds:42 Velocity mph=61.4233701 Drag&RR=34.3111803 distance in miles traveled=0.35830136
seconds:43 Velocity mph=62.8858313 Drag&RR=34.5671045 distance in miles traveled=0.37556645
seconds:44 Velocity mph=64.3482925 Drag&RR=34.8290505 distance in miles traveled=0.39323778
seconds:45 Velocity mph=65.8107537 Drag&RR=35.0970182 distance in miles traveled=0.41131534
seconds:46 Velocity mph=67.2732149 Drag&RR=35.3710076 distance in miles traveled=0.42979914
seconds:47 Velocity mph=68.7356761 Drag&RR=35.6510188 distance in miles traveled=0.44868918
seconds:48 Velocity mph=70.1981373 Drag&RR=35.9370518 distance in miles traveled=0.46798545
seconds:49 Velocity mph=71.6605985 Drag&RR=36.2291065 distance in miles traveled=0.48768797
seconds:50 Velocity mph=73.1230597 Drag&RR=36.5271829 distance in miles traveled=0.50779672
seconds:51 Velocity mph=74.5855208 Drag&RR=36.8312811 distance in miles traveled=0.5283117
seconds:52 Velocity mph=76.047982 Drag&RR=37.1414011 distance in miles traveled=0.54923293
seconds:53 Velocity mph=77.5104432 Drag&RR=37.4575427 distance in miles traveled=0.57056039
seconds:54 Velocity mph=78.9729044 Drag&RR=37.7797062 distance in miles traveled=0.59229409
seconds:55 Velocity mph=80.4353656 Drag&RR=38.1078914 distance in miles traveled=0.61443403
seconds:56 Velocity mph=81.8978268 Drag&RR=38.4420983 distance in miles traveled=0.6369802
seconds:57 Velocity mph=83.360288 Drag&RR=38.7823269 distance in miles traveled=0.65993261
seconds:58 Velocity mph=84.8227492 Drag&RR=39.1285774 distance in miles traveled=0.68329126
seconds:59 Velocity mph=86.2852104 Drag&RR=39.4808495 distance in miles traveled=0.70705615
seconds:60 Velocity mph=87.7476716 Drag&RR=39.8391434 distance in miles traveled=0.73122727
seconds:61 Velocity mph=89.2101328 Drag&RR=40.2034591 distance in miles traveled=0.75580463
seconds:62 Velocity mph=90.672594 Drag&RR=40.5737965 distance in miles traveled=0.78078823
seconds:63 Velocity mph=92.1350552 Drag&RR=40.9501556 distance in miles traveled=0.80617807
seconds:64 Velocity mph=93.5975164 Drag&RR=41.3325365 distance in miles traveled=0.83197414
seconds:65 Velocity mph=95.0599775 Drag&RR=41.7209392 distance in miles traveled=0.85817645
seconds:66 Velocity mph=96.5224387 Drag&RR=42.1153635 distance in miles traveled=0.884785
seconds:67 Velocity mph=97.9848999 Drag&RR=42.5158097 distance in miles traveled=0.91179979
seconds:68 Velocity mph=99.4473611 Drag&RR=42.9222776 distance in miles traveled=0.93922081
seconds:69 Velocity mph=100.909822 Drag&RR=43.3347672 distance in miles traveled=0.96704807
seconds:70 Velocity mph=102.372284 Drag&RR=43.7532786 distance in miles traveled=0.99528157
seconds:71 Velocity mph=103.834745 Drag&RR=44.1778117 distance in miles traveled=1.0239213
seconds:72 Velocity mph=105.297206 Drag&RR=44.6083665 distance in miles traveled=1.05296727
seconds:73 Velocity mph=106.759667 Drag&RR=45.0449431 distance in miles traveled=1.08241948
seconds:74 Velocity mph=108.222128 Drag&RR=45.4875415 distance in miles traveled=1.11227793
seconds:75 Velocity mph=109.684589 Drag&RR=45.9361616 distance in miles traveled=1.14254261
seconds:76 Velocity mph=111.147051 Drag&RR=46.3908035 distance in miles traveled=1.17321354
seconds:77 Velocity mph=112.609512 Drag&RR=46.851467 distance in miles traveled=1.20429069
seconds:78 Velocity mph=114.071973 Drag&RR=47.3181524 distance in miles traveled=1.23577409
seconds:79 Velocity mph=115.534434 Drag&RR=47.7908595 distance in miles traveled=1.26766372
seconds:80 Velocity mph=116.996895 Drag&RR=48.2695883 distance in miles traveled=1.2999596
seconds:81 Velocity mph=118.459357 Drag&RR=48.7543389 distance in miles traveled=1.3326617
seconds:82 Velocity mph=119.921818 Drag&RR=49.2451112 distance in miles traveled=1.36577005
seconds:83 Velocity mph=121.384279 Drag&RR=49.7419053 distance in miles traveled=1.39928463
seconds:84 Velocity mph=122.84674 Drag&RR=50.2447211 distance in miles traveled=1.43320545
seconds:85 Velocity mph=124.309201 Drag&RR=50.7535587 distance in miles traveled=1.46753251
seconds:86 Velocity mph=125.771663 Drag&RR=51.268418 distance in miles traveled=1.50226581
seconds:87 Velocity mph=127.234124 Drag&RR=51.7892991 distance in miles traveled=1.53740534
seconds:88 Velocity mph=128.696585 Drag&RR=52.3162019 distance in miles traveled=1.57295111
seconds:89 Velocity mph=130.159046 Drag&RR=52.8491264 distance in miles traveled=1.60890312
seconds:90 Velocity mph=131.621507 Drag&RR=53.3880727 distance in miles traveled=1.64526136
seconds:91 Velocity mph=133.083969 Drag&RR=53.9330408 distance in miles traveled=1.68202585
seconds:92 Velocity mph=134.54643 Drag&RR=54.4840305 distance in miles traveled=1.71919657
seconds:93 Velocity mph=136.008891 Drag&RR=55.0410421 distance in miles traveled=1.75677352
seconds:94 Velocity mph=137.471352 Drag&RR=55.6040754 distance in miles traveled=1.79475672
seconds:95 Velocity mph=138.933813 Drag&RR=56.1731304 distance in miles traveled=1.83314615
seconds:96 Velocity mph=140.396275 Drag&RR=56.7482072 distance in miles traveled=1.87194182
seconds:97 Velocity mph=141.858736 Drag&RR=57.3293057 distance in miles traveled=1.91114372
seconds:98 Velocity mph=143.321197 Drag&RR=57.916426 distance in miles traveled=1.95075187
seconds:99 Velocity mph=144.783658 Drag&RR=58.509568 distance in miles traveled=1.99076625
seconds:100 Velocity mph=146.246119 Drag&RR=59.1087317 distance in miles traveled=2.03118687
seconds:101 Velocity mph=147.70858 Drag&RR=59.7139172 distance in miles traveled=2.07201372
seconds:102 Velocity mph=149.171042 Drag&RR=60.3251245 distance in miles traveled=2.11324682
seconds:103 Velocity mph=150.633503 Drag&RR=60.9423535 distance in miles traveled=2.15488615
seconds:104 Velocity mph=152.095964 Drag&RR=61.5656042 distance in miles traveled=2.19693172
seconds:105 Velocity mph=153.558425 Drag&RR=62.1948767 distance in miles traveled=2.23938352
seconds:106 Velocity mph=155.020886 Drag&RR=62.830171 distance in miles traveled=2.28224157
seconds:107 Velocity mph=156.483348 Drag&RR=63.471487 distance in miles traveled=2.32550585
seconds:108 Velocity mph=157.945809 Drag&RR=64.1188247 distance in miles traveled=2.36917636
seconds:109 Velocity mph=159.40827 Drag&RR=64.7721842 distance in miles traveled=2.41325312
seconds:110 Velocity mph=160.870731 Drag&RR=65.4315654 distance in miles traveled=2.45773611
seconds:111 Velocity mph=162.333192 Drag&RR=66.0969684 distance in miles traveled=2.50262534
seconds:112 Velocity mph=163.795654 Drag&RR=66.7683931 distance in miles traveled=2.54792081
seconds:113 Velocity mph=165.258115 Drag&RR=67.4458396 distance in miles traveled=2.59362251
seconds:114 Velocity mph=166.720576 Drag&RR=68.1293078 distance in miles traveled=2.63973045
seconds:115 Velocity mph=168.183037 Drag&RR=68.8187977 distance in miles traveled=2.68624463
seconds:116 Velocity mph=169.645498 Drag&RR=69.5143094 distance in miles traveled=2.73316505
seconds:117 Velocity mph=171.10796 Drag&RR=70.2158429 distance in miles traveled=2.7804917
seconds:118 Velocity mph=172.570421 Drag&RR=70.9233981 distance in miles traveled=2.8282246
seconds:119 Velocity mph=174.032882 Drag&RR=71.636975 distance in miles traveled=2.87636372
seconds:120 Velocity mph=175.495343 Drag&RR=72.3565737 distance in miles traveled=2.92490909
seconds:121 Velocity mph=176.957804 Drag&RR=73.0821941 distance in miles traveled=2.97386069
seconds:122 Velocity mph=178.420266 Drag&RR=73.8138363 distance in miles traveled=3.02321854
seconds:123 Velocity mph=179.882727 Drag&RR=74.5515002 distance in miles traveled=3.07298261
seconds:124 Velocity mph=181.345188 Drag&RR=75.2951859 distance in miles traveled=3.12315293
seconds:125 Velocity mph=182.807649 Drag&RR=76.0448933 distance in miles traveled=3.17372948
seconds:126 Velocity mph=184.27011 Drag&RR=76.8006225 distance in miles traveled=3.22471227
seconds:127 Velocity mph=185.732572 Drag&RR=77.5623734 distance in miles traveled=3.2761013
seconds:128 Velocity mph=187.195033 Drag&RR=78.3301461 distance in miles traveled=3.32789657
seconds:129 Velocity mph=188.657494 Drag&RR=79.1039405 distance in miles traveled=3.38009807
seconds:130 Velocity mph=190.119955 Drag&RR=79.8837566 distance in miles traveled=3.43270581
seconds:131 Velocity mph=191.582416 Drag&RR=80.6695945 distance in miles traveled=3.48571979
seconds:132 Velocity mph=193.044877 Drag&RR=81.4614542 distance in miles traveled=3.53914
seconds:133 Velocity mph=194.507339 Drag&RR=82.2593356 distance in miles traveled=3.59296645
seconds:134 Velocity mph=195.9698 Drag&RR=83.0632387 distance in miles traveled=3.64719914
seconds:135 Velocity mph=197.432261 Drag&RR=83.8731636 distance in miles traveled=3.70183807
seconds:136 Velocity mph=198.894722 Drag&RR=84.6891102 distance in miles traveled=3.75688323
seconds:137 Velocity mph=200.357183 Drag&RR=85.5110786 distance in miles traveled=3.81233463
seconds:138 Velocity mph=201.819645 Drag&RR=86.3390687 distance in miles traveled=3.86819227
seconds:139 Velocity mph=203.282106 Drag&RR=87.1730806 distance in miles traveled=3.92445615
seconds:140 Velocity mph=204.744567 Drag&RR=88.0131142 distance in miles traveled=3.98112626
seconds:141 Velocity mph=206.207028 Drag&RR=88.8591696 distance in miles traveled=4.03820261
seconds:142 Velocity mph=207.669489 Drag&RR=89.7112467 distance in miles traveled=4.0956852
seconds:143 Velocity mph=209.131951 Drag&RR=90.5693455 distance in miles traveled=4.15357403
seconds:144 Velocity mph=210.594412 Drag&RR=91.4334661 distance in miles traveled=4.21186909
seconds:145 Velocity mph=212.056873 Drag&RR=92.3036085 distance in miles traveled=4.27057039
seconds:146 Velocity mph=213.519334 Drag&RR=93.1797726 distance in miles traveled=4.32967793
seconds:147 Velocity mph=214.981795 Drag&RR=94.0619584 distance in miles traveled=4.3891917
seconds:148 Velocity mph=216.444257 Drag&RR=94.950166 distance in miles traveled=4.44911172
seconds:149 Velocity mph=217.906718 Drag&RR=95.8443953 distance in miles traveled=4.50943797
seconds:150 Velocity mph=219.369179 Drag&RR=96.7446464 distance in miles traveled=4.57017045
seconds:151 Velocity mph=220.83164 Drag&RR=97.6509192 distance in miles traveled=4.63130918
seconds:152 Velocity mph=222.294101 Drag&RR=98.5632138 distance in miles traveled=4.69285414
seconds:153 Velocity mph=223.756563 Drag&RR=99.4815301 distance in miles traveled=4.75480534
seconds:154 Velocity mph=225.219024 Drag&RR=100.405868 distance in miles traveled=4.81716278
Re: Back to Basic
Post by PyroJoe » Mon Feb 08, 2010 9:42 pm
An example run for a model aircraft:
.12 for Cd.
.25 square feet for a frontal area
rolling resistance of 1 pounds (in this case substituting 1 pound of lift induced drag, just a wild guess)
vehicle weight of 3.4 pounds
Jet produces 3.8 pounds thrust
output of program:
Drag Coefficient Cd 0-1 .12
Frontal Area of vehicle in sq. feet .25
Rolling Resistance pounds 1
Total Weight in pounds 3.4
Thrust of engine in pounds 3.8
acceleration=35.9591765ft/sec^2
seconds:0 Velocity mph=0 Drag&RR=1 distance in miles traveled=0
seconds:1 Velocity mph=24.5177318 Drag&RR=1.04612168 distance in miles traveled=0.3405225e-2
seconds:2 Velocity mph=49.0354635 Drag&RR=1.1844867 distance in miles traveled=0.0136209
seconds:3 Velocity mph=73.5531953 Drag&RR=1.41509508 distance in miles traveled=0.30647025e-1
seconds:4 Velocity mph=98.0709271 Drag&RR=1.73794681 distance in miles traveled=0.05448360
seconds:5 Velocity mph=122.588659 Drag&RR=2.15304189 distance in miles traveled=0.85130626e-1
seconds:6 Velocity mph=147.106391 Drag&RR=2.66038032 distance in miles traveled=0.1225881
seconds:7 Velocity mph=171.624122 Drag&RR=3.2599621 distance in miles traveled=0.16685603
seconds:8 Velocity mph=196.141854 Drag&RR=3.95178723 distance in miles traveled=0.2179344
WebPilot
Re: Back to Basic
Post by WebPilot » Mon Feb 08, 2010 11:39 pm
 Well, where are the graphs/plots?
 I think you made an error in programming early on. Can you draw a flow chart? I think you'll see what I mean right away.
 I hope you're writing the data to a data file and not sending it to the screen, eh?
Ghrey
Re: Back to Basic
Post by Ghrey » Tue Feb 09, 2010 2:22 am
Hmmmmmm.
And I thought that the velocity of the acting thrust came in at some point.
Or have I ( yet again ) missed something.
I should sleep some time this week.....
