Linear Fwe Plusejet won`t run!!??
sprudelflasche1990
Post by sprudelflasche1990 » Sun Nov 01, 2009 7:00 pm
Hello, my name is Tim, I´m new here and I have a problem with my self-builded Pluse jet. It won`t start it only runs with blowing air into the intake, but also it runs to slow. I have tried to change the fule-nosle position but it didn`t help. I run it on 35% propan and 65% butan, maybe thats the problem but im not shure.
I have added a short clip, the plans and fotos of my pulsejet, I hope you can help me...
greetings from Germany
Tim
here is the video: http://www.youtube.com/watch?v=mcDbjRerqnw
the check valve maybe the problem?? but dangerous with out....
Re: Linear Fwe Plusejet won`t run!!??
Post by metiz » Sun Nov 01, 2009 7:59 pm
2 Things:
A: Flare your intake. This will make a world of difference
B: The fuel tank you have will not give it enough fuel and therefore, it wil not run. in your video, it's not running. Get a big BBQ sized tank without a regulator to fix it right up
That build is beautifull and it should run HARD once you flare and use a different tank - Good work!
http://www.tulsapowerservice.com/TankImages/20L.jpg
http://www.tgildeverhuur.nl/plaatjes/Ga ... .duits.jpg
Post by tufty » Sun Nov 01, 2009 8:12 pm
Also, lack of regulator / check valve is not a danger. Propane won't burn without the presence of oxygen, and as all that's in a propane tank is propane, there's no danger of "flashback". The worst case is that you will get a big flame coming from the ball valve on the tank, turn off the valve and it goes out.
sprudelflasche1990
Post by sprudelflasche1990 » Sun Nov 01, 2009 8:26 pm
hey, thank you for your posts, I will try it....
very good and friendly support, you are top...!!
greetings
Tim
