Piercing a gas canister?
Hi.
I have a helium cylinder from a party which I wish to use for 'something' (I dont know what yet). I will probably need to drill into it at some point, but am a bit weary.
I am sure it is empty, so I should be fine... BUT... there is the 'do not pierce' sign which always puts me off.
Any advice? Go for it or stay away?
Thanks.
JS.
Thanks.
JS.
With helium being non flammable, I do not see any problem. For extra caution, you may want to do it outside, to vent any remaining helium away. They put that warning on the bottle, because if you were to pierce a pressurized bottle, you would be in some trouble!
I have punctured propane cylinders without any problem....
Louder is ALWAYS Better!!!
hmm... I have a guess this is one of those small "propane" type cylinders?
Anyways, if you've completely de-pressurized the system, you have nothing to worry about. However, make SURE IT IS EMPTY! Once it is, go ahead and drill it (don't use it anymore once you've drilled it like NickC said) The residual helium won't hurt you, and it's not flammable.
well, you could always drill a tiny hole. If it still, for some reason, has pressure, it should just vent safely. I personally don't think you have anything to worry about. But, give it a go, wear goggles and gloves. And, if nothing else, you can use the metal to make parts with.
xxx
Insure you have depressurized it. Take out the valve stem and fill it with water.
Jim
Jim
WHAT TO FRAP, IT WORKED![url=callto://james.a.berquist]
[/url]
Hi again.
When you say never presurise it again, what exactly do you mean? i.e. never refill, or that a hole would damage the structural integrity? It would be good to use as a presurised fuel tank, obviously not going to use massizely high pressures, but what do you think it could handle?
Thanks.
JS.
Thanks.
JS.
Drill it, weld it... Do whatever your heart desires with it... When finished with it... Take it to your local plumber and have them pressure test the tank with water to about the double of your working pressure...
"woot"
Sorry to bother you sir but with the regulator on my LPG cylinder, i cant get enough fuel in my engine cause i want my engine to move forward and for this i need a lot of pressure and fuel flow. :(
The problem is this that many people told me that without the regulator on, i will get the LPG container blow up as there will be a flashback from the engine......Please i need a little HELP!!! :cry:
