start without spark :D
is it possible to start a pulsejet without a sparkplug? how?
re: start without spark :D
Propane torch at the end of the tailpipe. I like using the torch because it doesn't go out easily.
Mathematically, it can be described in terms of extra dimensions that are rather peculiar. Whereas ordinary space and time dimensions are described by ordinary numbers, which have the property that they commute.
yes!!
- Imagen113.jpg (13.47 KiB) Viewed 8130 times
- Imagen112.jpg (17.56 KiB) Viewed 8132 times
- Imagen118.jpg (17.02 KiB) Viewed 8130 times
- foto mia.jpg (9.58 KiB) Viewed 8131 times
- 25-12-05 a las 12 de la noche en punto.jpg (10.26 KiB) Viewed 8129 times
- DSC00154.JPG (22.24 KiB) Viewed 8129 times
- DSC00021.JPG (145.26 KiB) Viewed 8130 times
The famous Italian Zanin engines, the Rolls Royce of valved pulsejets, never used the spark plug, but a kind of a kitchen gas igniter on a long stick, which you simply pushed up the engine tailpipe so that the tip would enter the chamber. Once the engine caught, you simply pulled the thing out. The advantage was one less fitting on the engine and appreciably less mass. This was important in flying model competition.
Hahaha, Francisco! I do believe that is the very first picture I've seen of a pulsejet running on a city sidewalk.
that tears it. I've got to lay in a case of sparklers!
that pulsejet was encendio for New Year and Christmas in the street. for that reason the 7 denunciations by noises the noises were listened to from 4 blocks!
francisco cooreman
francisco cooreman
Re: re: start without spark :D
Hahahaha... hope you didn't have problems with teh police.francisco wrote:that pulsejet was encendio for New Year and Christmas in the street. for that reason the 7 denunciations by noises the noises were listened to from 4 blocks!
francisco cooreman
Sounds like you had great fun.
LOL on the sidewalk!
would like to see peoples reaction walking by!
If it doesn't fit, use a bigger hammer!
My guess is that NOBODY walked by!
