All right, gentlemen - here is one that UFLOW1D says will work, IF I estimated a reasonable cool gas temp for the SNECMA-style tail cone, even with the cone severely reduced in size as shown on the plan.
The hard part will be final tuning. There are basically only two practical things you can do, either: (1) Alter the intake length slightly; OR (2) Alter the straight mid-section WITHOUT changing the annular gap in the intake cone of the tail end.
Use whatever convenient fuel / starting method you're accustomed to at the intake. I will be delighted to engage comments and suggestions on this engine design.
