75mm Locky Kazoo (say that 10 times fast)
Locky Kazoo lives!
Mike, You Da Man!
If this one is made of 3 inch pipe, think of what you can do with 5 inch. Can't wait for more pictures, video and optimized plans so the rest of us can start making noise in our own neighborhoods. My next surfing stop, the stainless shop at Burns.
Dave
Dave
Thanks, guys! It was very satisfying. Here's the failed attempt at something different and slightly augmenting at the tail, before I squash it and weld it on as a permanent extension. I plugged the little crescent shaped outlets and tried again. Both cases made some very loud bangs and aaalmost wants to run. Bigger bangs than with the original length.
- MVC-669S.JPG (53.26 KiB) Viewed 16962 times
Thats really cool Mike well done, you are the first to come with new engine construction method that works:-)
I did have a go at analyzing the sound from your video clip but the microphone is overloaded so the output looks like a squire wave.
Great, great stuff Mike! Congratulations. I particularly liked the crowd of people gathering in the background....
So, the concept works. Refine it, and you may have a product to sell -- possibly the first on the market after the Dynajet and the first valveless after the demise of the Chinese and the Thermojet.
I'm tickled pink by this. Great, great stuff.
Plane of squash
I wonder if it would work as well if the flattened throat were in the same plane as the flattened tail? That way you could just strategically run over a piece of pipe with your car tire a few times, ha, a kind of automobile jet artwork, I guess it would require a "bit" of planning/experimentation/molding though to get the form you wanted, perhaps make a cement template for the pipe to lay in, maybe insert some round bar stock to keep the combustion chamber from deforming.
I have to wonder what is next? What comes to my mind is a twisty jet, if there was some way to carefully twist/crimp a pipe like the way you roll a joint, let's say.
I have some of that ribbed car exhaust pipe that has little chokes along the length of it, it's for bending the pipe however you want it, common stuff, but maybe a jet could be formed by pythoning, squeezing the pipe by gradually increasing or decreasing the waist of the pipe, the anaconda constriction method, maybe strong cable could be used to fashion it.
The old indian trick of wet rawhide that shrinks when dried came to mind foolishly, then once I recall the time I wrapped a pallet of boxes with one of those automatic plastic wrapper deals with the spinning pallet feature. It was a tight wrap and I didn't think anything more about it until an hour later, the boxes had given way and crumpled rather disturbingly. Would a metal pipe slowly deform if tightly wire-wrapped I wonder.
Congratulations again Mike on your form following function. Art and science, what could be better?
That's next, to see if the mixing is better, different or worse. As to the rest of your forming ideas, every wee hour is spent mulling over these techniques and more, though I like the idea of running it over with a car!I wonder if it would work as well if the flattened throat were in the same plane as the flattened tail?
I've been thinking of a "python" rig to make seamless cones, also. We're starting to think alike, Mark, I wonder if our menstrual cycles will fall in to synch?
Thoughts for a Generation 3 or 4 Locky Kazoo
Thanks Mike for jump starting a brave new world of pulse jet engines for the masses. Those of us who love noise and flames will praise your name and our neighbors will forever....
You success, and the input of others, has given rise to more thoughts about what a Locky Kazoo might look like several generations down the road? Something I have been pondering is the possibility making the combustion chamber in the shape of a U bend. This could still make it possible to get the Lockwood shape using low cost exhaust pipe from a local muffler shop. Many shops now have bending machines so they do not have to stock every pipe for every car. They just consult the magic manual, select the right size pipe, clamp on a positional dial, get out the tape measure, pop the pipe into the bender and go for it. By using standard 3 inch stock, and having the muffler shop do the U bend for the combustion chamber, it might be possible to create a quick and low cost Lockwood that should produce useful forward thrust. I look forward to your thoughts and the input of those on the forum.
Dave
Dave
Jeeez, do you all realise that we have just witnessed a historic event?
The birth of a new pulejetdesign.
Looks really good!
I guess one could make a whole lot of them and tune them into some kind of musicinstrument from hell ;-)
Someting tells me that my neighbors hate for my humble existense will kick into overdrive before the summer is over.
Looks really good!
My sincerest thanks to all of you guys! Your very kind words, and the input of this group is very important to me.
I'm working out a simple method of putting in the u-bend. I will be posting plans that allow you to hand saw a form out of wood and use Mark's beautiful idea: run it over with your (and in some cases, your Dad's) car. I'd like to get it to under an hour to complete forms, smash and get the engine running. How fun!!!
