Lockwood Pulse Jet won't sustain
saurav
Re: Lockwood Pulse Jet won't sustain
Post by saurav » Thu May 16, 2013 3:09 am
Hi Chook
Are you sure that you propane tank holds 8kg of propane? Because we have the same tank size and it holds 4kg of propane and 4kg is the tank's weight itself. So the total weight comes out to be 8kg including the weight of gas tank and propane.
How much speed do you get out with that engine?
Chook
Location: Esperance, on the south east coast of Western Australia
Post by Chook » Thu May 16, 2013 3:35 am
Back again!!!! :lol:
No my gas cylinder "tare" (empty weight) is 8.75 kgs empty and takes 8.5 kgs of gas to fill.
It stands a total height of 450mm and is 1050mm distance around the middle.
The measurements are.............
My nozzles radial holes, are situated exactly 15mm from the intake into the transition cone (which is total 40mm long from the intake tube to the combustion chamber)
The best speed is only 64.3 kmh on hard packed salt.
Although this was not in a straight line.
It was just a crowd pleaser run and I kept close so it could be filmed. :twisted:
When I get more time I really wan't to get it running on petrol/methanol.
I just need to know what size jetting I will need for the petrol? :?: :?:
Chook
saurav
Post by saurav » Thu May 16, 2013 7:30 pm
Well best of luck Chook for running your engine on liquid fuel......
Found some signs of life!!!! :D
It generated the sounds of life for about 1 second.
after that my little 4.5Kg tank couldn't generate enough pressure
Is there any minimum propane tank capacity ideal for starting the engine?
Chook
Post by Chook » Fri May 17, 2013 3:32 am
Awwww you are nearly there!!!! :D :D :D
If you have to continually hold the air in it to run/start it means that you have too much gas flow. As soon as it starts and you pull the air away, it will quit as it's mixture is too rich.
On mine if you can hear the injector hissing gas before the ignition, it has way too much gas and requires a LOT of air to get it running.
Just crack the valve on the bottle slightly and slowly increase it, very very slowly. I kept getting too excited when it's rumbling and would always give it too much gas.
It is amazing how low down it will idle, but needs warming up before full power is added or it just flames out.
The last 1/2 of the bottle when mine is running its very tame. Not much thrust at all.
I'm out of town for the next 3 days and hope you have positive news, by the time of my return. :mrgreen:
saurav
Post by saurav » Fri May 17, 2013 6:18 am
it's alive
yeeeeeeeaaaaaaahhhhhhhhhh
thanks chook, a ton.
it finally came to life.
soon the video will be posted
the problem was with the gas tank, it wasn't big enough.
Then I installed the one used by, Chook.
thanks thanks thanks thanks
now I have a headache :shock:
PyroJoe
Post by PyroJoe » Fri May 17, 2013 3:58 pm
congratulations! :D
saurav
Post by saurav » Fri May 17, 2013 4:03 pm
but the sound of it wasn't that loud, its not painful yet.
I think I will need to tilt the tank a bit next time.
by the way, will be posting the video soon
Chook
Post by Chook » Sun May 19, 2013 10:07 am
I am so pleased!!!!!! :D :lol:
Grinners are winners, you are very welcome.
Can't wait for the video.
You have given me a fantastic start to my week. 5 gold stars mate. :mrgreen:
saurav
Post by saurav » Wed May 22, 2013 6:25 pm
here is the video
but......
there are two things...
1. video camera was not recording the sound correctly, and
2. The engine's sound was itself not very intense.
so, will be making the video again with liquid. I guess the throttle was very low, but still it had a very deep rumble to it :roll:
754806_637943656219488_738898797_n.mp4
(1.62 MiB) Downloaded 190 times
Chook
Post by Chook » Thu May 23, 2013 1:16 pm
AWESOME !!!!!!!!!!!!!!! :D :D :D :D :D
Very well done. They attract a crowd where ever you run them.
That is indeed just above an idle.
You would not be still smiling and sitting by it without hearing protection at full power.
saurav
Post by saurav » Thu May 23, 2013 1:38 pm
that is why I was consulting you
I will be testing it with tank inverted
saurav
Post by saurav » Wed May 29, 2013 7:16 am
I was wondering if you guys could compare the swizzlestick injector and the radial injector
Chook
Post by Chook » Fri Aug 16, 2013 2:51 pm
Hey do we have an update on your motor yet?
Did she go in the end?
Chook
saurav
Post by saurav » Fri Aug 23, 2013 6:40 am
Hi all!!
Sorry for a late reply, I was busy with my studies....
Anyways,,,
I have been trying to find a solution to the wiggling injector due to extreme vibrations of the engine. Looking for a solid and firm grip now....
Chook
Post by Chook » Fri Aug 23, 2013 11:56 pm
Good luck with your studies!!!!!
I'm sure you will let us know your updates. :mrgreen:
