FWE VIII problem
FWE VIII problem
Postby Amir-J » Sun Mar 11, 2012 6:00 pm
Hi all friends.
i have made a FWE VIII pulse jet but i cant start it.
i did all start procedure by the rule . i use butane gas and i control gas flow by capsule valve and a hand ball valve.i am sure about engine leakage,ignition system and fuel nozzle .i positioned the adjustable fuel line and blower line in optimum situation .
....Now when i start engine, the pulse waves and thrust are available and engine works properly but When i remove the air hose , engine stop immediately!!!!!!...... :(
what can i do with the air hose? :?:
Amir-J
Re: FWE VIII problem
Postby metiz » Sun Mar 11, 2012 8:06 pm
Do you use a regulator on your gas tank? also, try propane if you have it handy
Postby Amir-J » Sun Mar 11, 2012 8:20 pm
metiz wrote:Do you use a regulator on your gas tank? also, try propane if you have it handy
No dear . i dont use regulator but i can control gas flow by tank valve and the ball valve.(also the gas pressure is not so high)
Amir-J
Postby Jutte » Thu Mar 15, 2012 2:57 am
1)Use a Rossco injector and try different positions in the intake
2)Use a bigger Propane tank.
3)Change Diameter of Intake to bigger Dia.
4)Change length of intake by using a sliding piece of pipe .
Try 1) and 2) first
Jutte
Postby Amir-J » Fri Mar 16, 2012 5:29 pm
Jutte wrote:1)Use a Rossco injector and try different positions in the intake
Try 1) and 2) first
thank you jutte. :)
1) what is Rossco injector?
2) I made the engine by standard size.(do i need to change the lenght and diameter of intake)?
Amir-J
Postby gettylee » Tue Feb 19, 2013 3:26 am
I posted a pic of my engine in valved section under,Identify this engine,mine is slightly diff. As yours,I can run it on 14oz propane can,I have better luck w/a torch flickering into the intake&set my air@20psi&start out w/air nozzle approx. 8or10" away from intake,than slowly increase fuel&move air in closer till she starts,here is a pic
gettylee
Who is online
Users browsing this forum: Google [Bot] and 0 guests
