youtube
Moderators: Tom, WebPilot, larry cottrill, Mike Everman
Re: youtube
Postby Mark » Tue Feb 07, 2012 4:54 pm
Look how far he takes his topic. He would be a good jam jar designer or helper I bet.
Part 1 Make a Robot Voice Talk Box
http://www.youtube.com/watch?v=THs8jNgY-dE
Somewhat related tidbit.
I remember reading books on making mechanical vowel sounds in the 1800's so the topic interested me.
"Alexander Graham Bell in particular was interested in how Helmholtz used resonators to mimic vowel sounds. Due to not being able to read German, Bell misconstrued Helmholtz' diagrams as meaning that Helmholtz had transmitted vowel sounds over a wire, whereas Helmholtz was merely using electrical stimulation to keep his resonators in motion without manual intervention. Bell reasoned that if vowels could be transmitted, then consonants also should be possible. He tried, and failed, to reproduce what he thought had already been done by Helmholtz. However, Bell was later to say that if he had been able to read German he would probably have given up the task as impossible, but in the event, went on to invent the telephone using the harmonic telegraph as the basis.[8]"
http://en.wikipedia.org/wiki/Hermann_von_Helmholtz
Re: youtube
Postby Mark » Tue Feb 07, 2012 6:57 pm
The First Noble Truth - Arthur Ganson
http://www.youtube.com/watch?v=CgHiSwR0 ... ure=relmfu
"Caught in a symbiotic relationship, both the wishbone and the machine are unable to manifest fully without the other. We drag our pasts with us and move according to unseen forces. More and more, we interface with the world through our mental and technological creations."
Machine with Wishbone - Arthur Ganson
http://www.youtube.com/watch?v=4pZXoayE ... ure=relmfu
"Each worm/worm gear pair reduces the speed of the motor by 1/50th. Since there are 12 pairs of gears, the final speed reduction is calculated by (1/50)12. The implications are quite large. With the motor turning around 200 revolutions per minute, it will take well over two trillion years before the final gear makes but one turn. Given the truth of this situation, it is possible to do anything at all with the final gear, even embed it in concrete."
Machine with Concrete - Arthur Ganson
http://www.youtube.com/watch?v=5q-BH-tv ... re=related
Re: youtube
Postby Mark » Wed Feb 08, 2012 7:24 pm
If you stay with the story, there are several nice details.
LOST AT SEA
http://vimeo.com/18463353
Re: youtube
Postby Mark » Fri Feb 10, 2012 4:59 pm
Electromagnetic Railgun world record setting event
http://www.youtube.com/watch?v=6BfU-wMwL2U
Re: youtube
Postby Mark » Fri Feb 10, 2012 7:42 pm
Working Model of Stephenson's STEAM ENGINE made of GLASS ! Rare!
http://www.youtube.com/watch?v=73txXT21aZU
Re: youtube
Postby Mark » Fri Feb 10, 2012 8:42 pm
"Lawrence Welk" Bubble Solution
http://www.youtube.com/watch?v=tu3T8f-8Fgw
Re: youtube
Postby Mark » Fri Feb 10, 2012 9:09 pm
Hydrogen and Chlorine Reaction
http://www.youtube.com/watch?v=NN82GoBG98s
Re: youtube
Postby Mark » Tue Feb 14, 2012 2:03 am
"Paul Eisner made an attempt on his existing World Record for Control Line Speed (1.0 to 2.5cc) which he had held at just over 194 mph since 1987. In unseasonably warm conditions (24C) the best run of the afternoon registered a provisional speed of 208.28 mph. This beats his existing record by the considerable margin of around 14 mph. The model is powered by an Irvine 15 "special" and uses a single-blade carbon fibre prop - as is usual with models of this type."
F2A World Record - Control-line model aircraft speed.
http://www.youtube.com/watch?v=4vAw1CC4A3g&feature=fvsr
Re: youtube
Postby Mark » Tue Feb 14, 2012 4:17 am
A História Da Eletricidade - Choque e Temor - Episódio 3/3 - Revelações e Revoluções
http://www.youtube.com/watch?v=8iZ9qXbcK9w
A História Da Eletricidade - Choque e Temor - Episódio 2/3 - A Era da Invenção
http://www.youtube.com/watch?v=9VPc1dygooc
A História Da Eletricidade - Choque e Temor - Episódio 1/3 - Faísca
http://www.youtube.com/watch?v=Q13Lwj3sAfU
Re: youtube
Postby Mark » Thu Feb 16, 2012 2:34 am
Half Bridge SSTC running from 340VAC
http://www.youtube.com/watch?v=wRdrem0zNwo
Another version. Also just after this segment/demo a powerfully sad epilogue follows, well worth watching.
http://www.youtube.com/watch?v=9VPc1dygooc#t=51m29s
Re: youtube
Postby PyroJoe » Thu Feb 16, 2012 10:19 pm
PyroJoe
Re: youtube
Postby Mark » Sat Feb 18, 2012 2:48 am
Lec 17 | MIT 8.02 Electricity and Magnetism, Spring 2002
http://www.youtube.com/watch?v=qxuGDEz8wDg#t=44m28s
Re: youtube
Postby Mark » Sat Feb 18, 2012 5:51 am
Spherical Flame Propagation with Sound - aka "Modified Firejar trick"
http://www.youtube.com/watch?v=m__SEiu5ha4
Re: youtube
Postby Mark » Sat Feb 18, 2012 4:09 pm
Never Wet, Nano tech to the rescue.
http://www.youtube.com/watch?v=69j_BHcgWfo
Re: youtube
Postby Mark » Sat Feb 18, 2012 7:57 pm
Pop-up Fabrication of the Harvard Monolithic Bee (Mobee)
http://www.youtube.com/watch?v=VxSs1kGZQqc
PreviousNext
Return to Off topic forum
Who is online
