Do you say 8cm length and 4cm diameter of augmenter, sorry dont mistake me if iam wrong.PyroJoe wrote:8cm would indicate the individual augmentors would need to be near 4cm diameter each.
ok then i will make the augmenters fix it,test it and update it here. Waiting for the gas tank.PyroJoe wrote:8cm tailpipe diameter should give approximately 4cm on the augmentor diameters. The augmentor length is probably near 32cm. Not sure how reducing the intake diameters will affect it, but should be close enough to see considerable thrust improvement. Also let us know if the sound increases from adding the augmentors.
Still in the process of making augmenters, after testing with augs i will update herekevin lee wrote:Hi mate have you got any updates too share?
Have you designed that car/kart yet? I like the idea of those aero dynamic down hill gravity powered cars with a pulsejet or two shoe horned on.
We want more video
an important thing shall i place the augmenter at a distance of 6cm from the intake pipe or more than 6cm.PyroJoe wrote:8cm tailpipe diameter should give approximately 4cm on the augmentor diameters. The augmentor length is probably near 32cm. Not sure how reducing the intake diameters will affect it, but should be close enough to see considerable thrust improvement. Also let us know if the sound increases from adding the augmentors.
