Lady Anne variation.
Re: Lady Anne variation.
Have the dimensions for the latest revision been posted?
I think I would like to build this one.
ha, by accident I've read yesterday(maybe for the third time, I find it an fascinating design) this topic (and al the related topic like Jane grey,the BIG lady etc), and I also couldn't find the revised dimensions. It seemt to me that te conus from the sparkplug to the combustionchamber is elongated.
Are the inner dimensions of the inlets still 20.5mm?
I just last night calculated about 4 hours to a 20% scaling up of the Lady Jane Gray.
Because the topic was so old, I was planning to contact James or Graham by PM, but because you already did it here, I do it also in this topic
u
Hi. Yes Send me a PM and I'll send you a late drawing.
Dark days nurture new
light. Productions begin.
Now open your eyes.
Now open your eyes.
buy a pulsejet
I have a jet plan
so i want to buy a pulsejet for this
help pleas!
help pleas!
For the Snake fuel injector, how thin is the copper pipe? It seems like it would be difficult to get it to ball up on the end to drill the 4 holes.
Have these runs been on gaseous propane?
I read Graham used 1mm stainless and in the beginning James used 0.7 mm.
My local shop has some smaller stock of 314 stainless 0.7mm.
Would you guys recommend something(alloy/thickness) else?
Best Regards,
Cory
(P.S. Graham I tried your email but it bounced back)
Best Regards,
Cory
This has Graham mailed to me (I prefer with very old topics to contact the author/builder by pm
Good luck
I'm also planning to build such an engine, and I think when you're really interested, Graham will send the latest drawings to you.Ensure you have no restrictions between the Propane tank and the injectors.
The fuel pipes are 4mm O.D. thin wall copper made-up as shown in the photographs.
Good luck
After reading this thread several times over the years, a question surfaces:
James D, what inspired you to add a second intake?
If the centre of combustion had moved 'south' towards the tailpipe would that give an increase in frequency or is it just likely to be running hotter?
