FD3/64-2:1!
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
D-day not to far away!
I’m amazed how long this build has felt and how fast it, according to my calendar, actually have been executed.
Yes, I am aware of that getting the motor to actually run can consume 5x the building time, if it can be persuade to run at all, that is… :?
Well aware of forthcoming struggle I have tried to eliminate as many small irritating problems such as a proper way to mount the motor during the test phase etc.
Still have to make a turbine wheel, build a lubrications system, and make other smaller adjustments on the motor.
Cone glued in place.
Experimental EDF starter mounted.
Fastening point welded on to the outer shell.
Gas conection and negative-ground conection bits added.
Simple start box. Switches for Rpm meter, spark and EDF, electric ducted fan.
Inside box, laser tachometer, spark coil of BBQ type powered by a single 1.5V battery. Laser tachometer and EDF powered by 6V lead acid battery.
Fricke
Re: FD3/64-2:1!
Post by Fricke »
Wow! You are building fast!
Looking nice. I like the "Åsa-Nisse" approach on the control panel...
"woot"
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
Ha, ha, or maybe "Pettson" approach :D
Johansson
Re: FD3/64-2:1!
Post by Johansson »
That starter looks really interesting, any more info about it?
Fricke
Re: FD3/64-2:1!
Post by Fricke »
Axel Borg wrote:Ha, ha, or maybe "Pettson" approach :D
That's even better! =D I just love "Findus" 8) :lol:
Do you know of a good hobby shop that sells 1000W to 1500W brush-less inrunner motors?
"woot"
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
Always check hobbycity.com if you are in need of RC stuff!
Uppdate:
New aluminium center cone.
New smaller and 4x more powerful start motor. Spins up the turbine to 2500rpm.
Sevo tester to adjust the start motor EDF.
Shaft tunnel and lubrication system.
Lubrication.
Lubrication.
Air and oil sypply.
Air and oil sypply.
Johansson
Re: FD3/64-2:1!
Post by Johansson »
That starter, is it going to be permanently mounted to the inlet cone?
Are you going to build the turbine wheel from 1mm sheet or are you going for a slightly thicker material? The way Schreckling fitted his turbine wheel to the shaft looks quite daft to me by the way, why didn´t he drill a hole in the turbine wheel and make a neck on the shaft that goes through the hole and then weld it?
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
If the startmotor works, its permanent.... :)
Schreckling is very much against drilling holes in turbine discs because of the drastically decresed strength of the disc.
I will start experimenting using the 1mm material, if it does not work I will try thicker material.
Zippiot
Re: FD3/64-2:1!
Post by Zippiot »
Yeah I recall Shrecky saying something like if any hole were to be drilled through the disc it would fail prematurely. The little tool he describes to bend the blades is marvelous for random things around the shop!
Johansson
Re: FD3/64-2:1!
Post by Johansson »
Axel Borg wrote:If the startmotor works, its permanent.... :)
So the engine will suck air through the starting fan once it is running? Lots of space between the fan blades so that should work, will look interesting since the fan will rotate from the air pulled through it. 8)
But if you lay a weld around the hole the turbine wheel should not be more stressed than if it was undrilled, or am I wrong?
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
There is plenty of room for air being sucked in all around the fan as well.
I guess the weld itself might make up for lost strength due to the hole.
Screcklings way to do it is actually not bad; it makes it easy to dissemble the motor.
Axel Borg
FD3/64-2:1! Now; up and running!
Post by Axel Borg »
:D :D :D :D :D :D :D :D
What do you know, -it works....
Just to clarify: IT WORKS!!!!
Film clip on youtube: http://www.youtube.com/watch?v=EO_6E_QKmEU
Turbine Wheel
Turbine Wheel
Rotor assembly.
Rotor assembly.
NGV
NGV
0.5-0.6mm radial clearence.
ace_fedde
Re: FD3/64-2:1!
Post by ace_fedde »
Yeah! Haha! :D
Congratulations!
Fricke
Re: FD3/64-2:1!
Post by Fricke »
Nice!
Congratulations!!! =)
"woot"
Axel Borg
Re: FD3/64-2:1!
Post by Axel Borg »
Thanks!
Check this out!
The motor can self sustain and accelerate from 1800rpm!
Obviously the throttle response is slow since the pressure is extremely low.
It is hard to believe even when I se it with my own eyes, just amazing!
The motor is really quiet at these rpm:s.
http://www.youtube.com/watch?v=KYauppq5G5k
:D :D :D
