Post
by Eric » Mon Sep 18, 2006 9:25 pm
Thanks M. and Larry,
Its not something that I am going to make multiple identical units of before I get any orders, because the pulsejet market is just too slow, but if anyone is interested I can make these up pretty fast to order and for reasonable prices.
As with everything, its hard to make them really small, its not impossible but I would rather do as little precision machining of tiny stainless steel parts as possible! Anyone who has machined stainless knows why.
The fuel plane is the reason these work so well, the fuel is evenly distributed and mixing is innumerably better than any radial injector. I will have to remember to take a picture some night of one of them outside the engine.
The fuel mixing is so good that I have been able to move the injectors way farther back into the combustion chamber than normal, this can reduce power but really increase TSFC on some engines.
With it positioned vertical you can light it, crank up the fuel flow, and its like an upside down umbrulla of fire :)
With the angled ones, the mixing rate might not be as good, but the rosscojector effect is often worth it, especially with large engines. The large engines fire at a low enough frequency that mixing time is much higher, and still they mix fuel better than any radial injector. Medium and small engines really benifit from the 90 degree injection since the mixing rate is extremely high, for high frequency engines this really improves performance greatly.
One of the older injectors I tried before the "infinijectors" were basically a little vortex nozzle. You have a hole in the middle that forms a low pressure core, and around it a radial array of precisely angled fuel holes, that basically sucks in a massive volume of air and creates an extremely turbulent flame. Once you light it the flame will stay within 1" of the injector even at full blast, and create a bright blue flame about 3' long.
