oil seals???
oil seals???
how is the oil kept in in a ball bearing turbo?
re: oil seals???
if you use angular contact bearings do you just not need oil seals? let it burn off the oil??
re: oil seals???
NickC:
I've never built one! I would use metallic seals and flow oil from inlet to sump! Injection and return......
Keep it cool!!
Do what they do on a Automotive Turbo Charger......
Just a thought!!!
Jim
Keep it cool!!
Just a thought!!!
Jim
Re: re: oil seals???
Most ballbearing turbos have the same type of oil-seals as the normal ones.NickC wrote:if you use angular contact bearings do you just not need oil seals? let it burn off the oil??
