KKK24
KKK24
Hi all!
I'm kind of new to gas turbines,
I've built the FWE valvless pulsejet
from Erics free plans and now
I want build a "real" jet engien(sorry all pj fans!).
I've found a kkk24 turbo in nice
condition, is this a good turbo to start with?
I have looked around at as many
sites as posibel and I think I'm ready to start buildning.
/Mike
/Mike
If it doesn't fit, use a bigger hammer!
re: KKK24
Hi Mike -
How big is the inducer on the compressor?
Is the turbine inlet a single hole?
And a great help for You in building a GT is to join the DIYGasturbine group at Yahoo, there is Raketmotorman´s wisdom collected in a number of documents. And there is over 30k worth of messages to find info and ideas from!
//Fricke
//Fricke
re: KKK24
I'm not sure about the inducer diameter but the turbine wheel is 55mm in diameter.
I have joined the yahoo group and it has helped quiet a bit!
I've found the turbo on "Blocket"
http://www.blocket.se/vi/9104766.htm?ca=5_s
I have some more pics of it, but right now Hotmail isn't working so I'll post them ASAP.
The seller says there is only a small play when ther's no oil in it.
I think the turbo is worth 1500SEK (200$), but off course I'll try to get it cheaper ;)
/Mike
/Mike
re: KKK24
For some reason I can't post the pics, but the inlet is a singel hole.
re: KKK24
Finally I can post a picture of the turbo!
I think the inlet diameter is 65mm, bu I'm not quiet sure.
- (101.42 KiB) Downloaded 1296 times
re: KKK24
Turbo map for KKK 24 - http://not2fast.wryday.com/turbo/maps/k24-70gga.jpg
re: KKK24
Well, I found a new turbo, it's a KKK27 that's newly renovated, for not so much more $ and I think it's a bit bigger, but I'm not sure, I read somewhere that the KKK24 has an inducer diameter of 65mm, while the KKK27 just have 50mm.
http://www.blocket.se/vi/9528005.htm?ca=5_s
re: KKK24
That´s a nice turbo the KKK 27, try to get the asked price down to 1500:-- SEK.
Mostly because it´s your first GT and if everything go to h*ll, then you haven´t wasted too much money.
My last turbo costed me only 20:-- SEK and lasted 2 years before I got stupid and wrecked it. It was a nice little turbine, that I used on my jetkart.
re: KKK24
LOL 20 SEK! where did you find that!
Do you think the k27 will be able to puch a kart at something like 60-70km/h? I'm not planing to do build a jetkart right away, but some time in the future I'd like to put it on a go-cart
re: KKK24
I got at an surplus store.
One place to get a decent and cheap turbo is a scrapyard or truck repair shop.
A 50 mm inducer should give about 11 kg thrust (it is not a real figure, as we need to have some more dimmensions on the compressor to get a better estimate).
I got as max 13 kg thrust ( that was when my fuel nozzle got loose and leaked too much fuel) on a 52 mm inducer...
My Go-kart made ~80 km/h... But I hope it will go faster with my new 'Thor' VPJ when I build it... =)
//Fredrik
//Fredrik
re: KKK24
I've e-mailed the guy offering 1500 SEK and to my big suprise he said ok! so when I have some time I'll go and get it, he lives 1h driving away and I don't have a licens so I'll try to convinse my dad to drive me there asap.
