Another pocket lockwood success
Irvine.J
re: Another pocket lockwood success
Post by Irvine.J » Sun Jun 18, 2006 1:27 am
Hi Jansen, I'm a qualified audio engineer, who hasn't attempted audio analysis of a PJ yet, though would very much like to. Can you post the stereo recording of your engine so I can play around with it.
-I dont have a high quality stero recording of a PJ, and I dont have a PJ to record...yet :D - Plenty of mixers compressors etc etc I need something to work with.
I'll upload some software onto my website for all to trial for ananlysis.
I'm guessing those multiple peaks are harmonics, you can calculate what they -should- be from 710 hz.**just a guess**
47
Attempting to use the quote function below...
Time is E- There is no time.
Jmitchell
Post by Jmitchell » Sun Jun 18, 2006 1:32 am
I meant that I was running over 10PSI Acetylene, and didn't want to go above 15, as it can become unstable.
Re: re: Another pocket lockwood success
Post by Mike Everman » Sun Jun 18, 2006 7:10 am
Number47 wrote:Hi Jansen, I'm a qualified audio engineer, ... I need something to work with.
Here's a good recording to play with, made with a mixing board and a good mike. If you put your analysis software in oscilliscope mode, you'll see the clipping of typical video files.
This one has some reliable harmonic content.
mikhail chinese run 1.zip
(919.42 KiB) Downloaded 310 times
hagent
Post by hagent » Sun Jun 18, 2006 7:35 am
The frequency is changing - Lower at the start to higher at the end of the audio clip.
It appears to be around 267 - 268 Hz at the end. It's still shifting a Hz or two though. To my ears it appears to be the major tone of the PJ.
Hagen
Hagen Tannberg
