130R power failure
Man.... I am alusinating ....
One minute I see a question about line and tank pressure and by the time I answer it .... Poufffff .... Don't see it anymore. Mannnn ... I need some sleep. This thing is strating to posess me....
Okey guys, the supersonic Nozzle simulation as been pushed to next week. I am to run a Sim on an Ejector, then I will go back to the Nozzle.
Like I said, all the new Nozzle Simulation will include Nozzle, stage 1 and stage 2. For that, I need to redo the assembly and I don't have the time before the weekend. So ... Cya Monday, and the results will probably for thuesday.
Cya ... And play safe.
Luc .................... Out
Luc,
I have attached the kind of flow field I am imagining. I see you are already modeling 1st and 2nd stages, so my flow field is a little behind, but you'll get the point. Colors as follows:
Red: Nozzle inlet condition
Green: Axis
Blue: Free stream condion
Yellow: 'Metal' surface boundaries
Magenta: 'Control' surfaces
The control surfaces are where we want to measure the flows. They may or may not be easy to setup depending upon your pre- and post- processors. Ideally you post processor will allow some sort of area summation posts, so that we can measure the flows through these surfaces. Sometimes, pre-proccessors will allow you to merge meshes so that you can explicitly create the 'control' surfaces as shown.
Your choice to model the 1st and 2nd induction stages is of course correct. Eventual we would want to model the entire induction system. I've just found in the past that CFD is very unstable, so I like to start with simpler situations first and get them stable before moving on.
Regards,
Raymond
Green: Axis
Regards,
Raymond
- (4.38 KiB) Downloaded 429 times
130R power failure
Hi Raymond,
Here ... I have attached a picture showing you were the numbers will come from. But, between them, you will see colors and vectors that will give an idear of the speed, temp, flow and pressure.
Boundary Condition details :
Source Surface = 225 psi @ 1200° F
Surface 1 = Atmospheric, 14.69 @ 69°F
Surface 2 = Atmospheric, 14.69 @ 69°F
Surface 3 = Atmospheric, 14.69 @ 69°F
Calculation Surface Goals details :
From Surface 1 = You will get Mass flow and speed numbers
From Surface 2 = You will get Mass flow and speed numbers
From Surface 3 = You will get Mass flow, Speed, pressure and Temp.
Global Goals Conditions :
The entire assembly average static pressure, temp. and speed. Plus all the colored images and vectors.
- SupersonicTest.jpg (8.55 KiB) Viewed 10459 times
130R Power Failure
Here Raymond,
A #D view of the stack it self. You can also see the 4 surfaces and the entire assembly is the computational domaine.
I hope the setup will suite our needs.
Cya,
Luc
Cya,
Luc
- SupersonicTest1.jpg (7.57 KiB) Viewed 10458 times
Luc,
Does your CFD allow symmetry plane type boundary conditions. If so you can eliminate the transverse inflow to the fuel jet to make your domain axisymetric, and then model only a 'pie slice' of the flow domain. i.e. instead of rotating the axisymmetric flow field a full 360 degrees about the symmetry axis, just rotate it a small amount, say 10 degrees, and apply symmetry BC's to the symmetry planes. The computational domain should now be 1/36 the size it originally was and one of your '40-60 hour' computational times should reduce to 1-2 hours!
Regards,
Raymond
PS. Is your hotmail address the right one to contact you at? Have sent another email awhile ago.
Regards,
Raymond
130R power failure
Good morning guys ... And Hi Raymond,
Yes, mu CFD can do symmetry boudary conditions. I did not go that in first place, because I wanted to give you all, a total simulation results. But now that you mention it, I will do it this way.
After the entire weekend, the computation is still not complete ... Yes, 66 hours of full power 2.6 Ghz CPU ... And still not complete. You can now imagine, what type of computer NASA own, to run these live, in a 1 to 1 time frame.... Geeeeeeeeee.
Results should come soon.
Cya folks
Luc ........ Out
Cya folks
Luc ........ Out
130R power failure
Okey ... Update,
I just scraped 66 hours of calculation. I stoped the calculation, thinking I could setup the program to continu using a symmetry of the stack, but guess what .... Heinnnnnnnnn...Wrong think to do.
But, .... this simulation was getting nowere because the program had to much to calculate with, so, when restarting the simulation, I had the option of taking the previous results, wich I did. So mayby ... We did not loose all that 66 hours... He he he ... Ouupppsssss ... Sorryyyy.
Cya,
Luc ..........................Out
Cya,
130R power failure
Okey Guys,
CFD simulation of Raymond's supersonic nozzle is complete. Now, If only I can get a way to transfer the file to Viv, so he can post it, then you will be able to see it. I will try tonight using my own Internet account.
Furthermore, I think it should be important to run the Gluhareff Nozzle with the intake stack, under 700 psig. @ 1200 °F, like I just did with the supersonic nozzle. This way we will be able to compare both nozzle under the same condition.
My question ... Do I run the Gluey nozzle in its intake stack at 700 psig. or we don't need that?
As soon as Viv get the files, he will post it.
Maybe some day ... I should learn how to post downloadable file to.
Regards,
Luc ......................... Out
Regards,
130R power failure
Ouupppssss....
Made a mistake in my previous post and question.
The comparision is between the supersonic nozzle @ 225 psig.
and the Regular nozzle (Gluey one) @ 700 psig.
After all, this is what we are trying to achieve, match the gluey nozzle condition.
Cya .....
Luc ..................Out
Cya .....
well soon as I get the report I will post it but nothing in the inbox yet.
130R Power failure
Okey guys,
Let try something ... Let see if I can post a picture. How want to see my pressureJet at Max Power. We did a test yesterday and Pat took a picture.
Look....
Bye the way ... I am still trying to figure out how to transfer the repport of the Supersonic Nozzle analysis.
Cya,
Luc ....................... Out
Look....
Cya,
- (192.25 KiB) Downloaded 463 times
Looks hot:-) they must love it when you run that puppy up in the welding bay
nice pic
i think it's snowing in the machine shop lollll , well maybe not with the heat that produce . i go for dust on the lens ..haha .
next time i will take my digit cam , it will make a more clearly pic .
hoooo and by the way i'm anxious to see this gluey pushing the 750 pouds working table with the engine is clamped on .
did i dream again ? ...
PATRICK
PATRICK
Nice Picture!
Luc
Love the picture of the engine at full power!
Please sir, may I have another?
