Tutorials
Tutorials
I hope you like it...
- [Rocketry] Improvised Rockets.rar
- (257.48 KiB) Downloaded 648 times
The knowledge that you seek is the source of my power
re: Tutorials
- [Rocketry] Making Rocket Engines.rar
- (8.18 KiB) Downloaded 613 times
re: Tutorials
- [Ebook].[Weapons].[Rockets].[PVC Rocket Motor - How To Make It].pdf
- (173.82 KiB) Downloaded 681 times
re: Tutorials
Red_Armor,
I just downloaded 2 of your pdfs, namely,
unguided_aircraft_rockets_940.pdf and
hydrogen_micro-turbines_160.pdf
Acrobat Reader complains
"There was an error opening this document. The file is
damaged and could not be repaired"
I downloaded a 3rd pdf of yours and it opened properly.
Were these other 2 possibly damaged during your upload?
-fde
-fde
re: Tutorials
well, it's probably because they're .rar files, which I don't have the device to open either.
Re: re: Tutorials
Hmmm. I didn't think of that. I renamed it and opened (or tried) to openthecheat wrote:well, it's probably because they're .rar files, which I don't have the device to open either.
with WinRar, but it complained again about it being damaged.
Cheers,
-fde
re: Tutorials
WebPilot, sorry about that, I will check them and if possible repair them and ofercose upload them again.
re: Tutorials
- [Rocketry] I-RDX as solid rocket propellant paper.pdf
- (24.79 KiB) Downloaded 649 times
re: Tutorials
- Amateur_Rocketry.pdf
- (1.07 MiB) Downloaded 604 times
re: Tutorials
- [Rocketry] Composite_Rocket_Fuels.pdf
- (96.82 KiB) Downloaded 597 times
re: Tutorials
A bit of caution is in order if you decide to follow these "tutorials".
PLEASE take the time to understand the chemicals you'll be using, try to understand the dangers of handling them, breathing them etc.
Of NOTE; THF in the tutorial about composite rocket motors is very reactive in the presence of strong oxidizers and can explode. It'll form peroxides and that can make the stuff very shock sensitive.
Keep perchlorates and chlorates away from each other. Chlorates and metal are very dangerous, just don't do it.
Some of the tutorials appear to come from the "anarchist's cookbook". Be careful, not all of these things are safe or accurate.
re: Tutorials
- [Rocketry] Bottle rocket handbook.pdf
- (670.22 KiB) Downloaded 529 times
re: Tutorials
- [Rocketry] Rocket Systems.pdf
- (237.48 KiB) Downloaded 621 times
re: Tutorials
- C M Kornbluth - Theory Of Rocketry.pdf
- (28.29 KiB) Downloaded 579 times
re: Tutorials
- Rocketry - Sensitivity of Solid Rocket Propellants for Card Gap Test.pdf
- (117.85 KiB) Downloaded 630 times
