New set of linear FWE plans
steve
Post by steve » Mon Feb 28, 2005 11:25 pm
There seems to be some considerable interest in this engine and several requests for plans, so I thought I would whip some up. (by whip some up, I mean spend 5 hours debating with myself what to include, how to position everything, colors, fonts, etc) I think it was worth it though.
(114.24 KiB) Downloaded 2377 times
Re: New set of linear FWE plans
Post by mk » Tue Mar 01, 2005 6:21 pm
Very nice, Steve.
I'd suggest posting plans of other (front inlet) FWEs under this topic, too.
Post by Mike Everman » Tue Mar 01, 2005 7:16 pm
This is a proven engine and the plans are superb. Please post it above in the "looking for plans" sticky(?)
francisco
re: New set of linear FWE plans
Post by francisco » Fri Mar 25, 2005 4:55 am
hola: constui el fwe (entro otros) pero no consigo que este funcione, en realidad ninguno de los 3 fwe que constui funcionaron, a que debe.
los motores fueron costuidos a la perfeccion y tal cual lo indican los planos. ¿ puede haber una falla en los planos?.
usted me puede decir que relacion matematica hay entre la camara de combustion, la pipa de entreda y el caño de salida.
gracias .
francisco
"I DONT`T SUFFER OF MADNESS, I ENJOY IT CONTINUALLY"
fran_rio88@hotmail.com
steve
Post by steve » Fri Mar 25, 2005 5:34 am
An engine built exactly to those plans will run, this has been independently verified by at least two other people (nick and eric), so the problem must either be with your starting procedure or with your fuel supply. If you can give more specific information or post some pictures then we should be able to help you.
(mala traducción) Un motor construido exactamente a esos planes funcionará, esto ha sido verificada independientemente por por lo menos dos otras personas (Nick y Eric), así que el problema debe estar con su procedimiento que comienza o con su fuente de combustible. Si usted puede dar una información más específica o fijar algunos cuadros entonces debemos poder ayudarle.
francisco
Post by francisco » Fri Mar 25, 2005 5:44 am
me gustaria saber que cantidad de propano debo injectarle y que cantidad de aire. ¿ el aire es en forma constante?.
gracias de todas formas. no puedo fijar cuadros porque se rompio mi camara.jejeje
francisco.
