5 pounder scale up?
5 pounder scale up?
I am wondering if scaling up the plans by a % would incres trust on the G8-2-5 engine.
Re: 5 pounder scale up?
Maybe on a normal pulse jet you can scale them and get away with it but I afraid that the pressure jet has a complex interrelationship of parts that would not scale up or down and then run.JOHNEP wrote:I am wondering if scaling up the plans by a % would incres trust on the G8-2-5 engine.
The pressure jet has to be designed to run at a particular size it can not be scaled.
Hope that helps
Hi John,
Cya,
Luc
Nope ... That a No No ... Especially with pressurejet.JOHNEP wrote:I am wondering if scaling up the plans by a % would incres trust on the G8-2-5 engine.
Cya,
Luc
Luc
Designer & Inventor
Designer & Inventor
