Steam rocket project
Re: Steam rocket project
A couple of weeks we started to build a safety valve for the steam rocket, I finished it yesterday and put some paint on it. Next weekend we are planning to test it to find out what the pressure range is.
Olov brought the rocket kick to the workshop yesterday and fitted the safety valve, he also made some dry-run tests to find out the optimal driver position...
That'd be about 10 meters away from the thing right?Johansson wrote: he also made some dry-run tests to find out the optimal driver position...
Ha, I´ll tell that to Olov...metiz wrote:That'd be about 10 meters away from the thing right?
Hi Anders
Top man! that thing hauls
Yeah, I had to hold on good for sure.
At the starting moment you can see the front of the kick leaving the ground for a short period, with 90kg thrust and a total weight of 120kg with me included it is tends to go in the direction it is pointing. I wonder how it fast it would go if I had run it at 50bar as I was supposed to, a coupling started to leak so we decided that 40bar was enough.
Sorry for the Swedish text by the way, we had our fellow nordic racers in mind.
That's.....one of the coolest things I've seen
awesome work!
Now bolt on that Thunderchine!
Hahaha!! Whoah!! Hahaha!! Speechless!!
Anders, you're a fucking madman.
Can I have a go?
Can I have a go?
2nd.tufty wrote:Anders, you're a fucking madman.
Can I have a go?
Sure thing guys, next weekend perhaps?
That's gonna be a long hot winter...
I mean, for the legs
Actually the steam ejected from the nozzle is pretty cold, I guess that the pressure drop and rapid vapourisation of the overheated water gets the temps down very fast. You get a bit wet though...ace_fedde wrote:That's gonna be a long hot winter...
My 0-100km/h time was in the region of 5.5s, just before I hit the snow line on the lake the speed started to drop so I used a timing clock while watching the video to find it out. Not bad at all for a bucket of water.
An interesting thing I noticed that day was that the slow ramping down of thrust is completely gone, the G-forces makes the water inside the tank pool up against the nozzle so it accelerates just as hard all the way until it runs out of water.
During the static tests there were no G-forces acting on the water so once the water level got lower than the nozzle throat steam started to mix with the ejected water, that is why the thrust went down after a few seconds.
