Aluminum Powder and freon
I was just wondering what the reaction would be to mix freon and aluminum powder. Would it burn like aluminum and ammonium percholate would? Just wondering, as I dont want to blow my hands off trying to experiment with it, so ill ask you guys. :D
If you think hard, design it, you can build it!
kid20
What ever gave you that Idea?
Read and Heed! Phosgene Gas is a byproduct of combustion. Not Friendly Stuff......
http://en.wikipedia.org/wiki/Haloalkane
Jim
Jim
Re: Aluminum Powder and freon
If it's just freon and alumium. zip nada zero. You have mixed a fire extinquishing agent with some alluminium. Why do you think a non reactive gas flame supressing gas would do anything?
youngrocketkid20 wrote:I was just wondering what the reaction would be to mix freon and aluminum powder. Would it burn like aluminum and ammonium percholate would? Just wondering, as I dont want to blow my hands off trying to experiment with it, so ill ask you guys. :D
kid20
Markstreamnz: I think that was a joke or a test.
When combusted with other products, CFC's seem to form this wonder full thing call Phosgene Gas. It is the basis of our old friend called Chlorine Gas . The Chlorine fills the Red Blood cells with chlorine as so they can not carry oxygen. CFC's do the same to extinguish fire. It replaces the oxygen as to inhibit combustion. In the Ozone layers, it replaces oxygen and there for halts the production of Ozone.
Jim
Jim
Re: kid20
Jim not quite.berquistj@peoplepc.com wrote:Markstreamnz: I think that was a joke or a test.
Jim
CCl4 (Carbon tetra chloride) is the dangerous one for heating to phosgene. Most haloalkanes are quite hard to convert to phosgene, not that that matters as burning fluro carbons, many of which contain NO chlorine (ie HFC-134a), is dangerous because it liberates the halogens as gaseous acids ie HF HBr HCl. HF hydrogen fluoride is an EXTREMELY nasty molecule. These acids when inhaled destroy lung tissue so body fluids seep into the air spaces so you basically drown.
The reason Haloalkanes and quite a few other halogen based fire retardents (such as Antimoney tri Chloride) work so well is the halogen is liberated as a radical in the flame which interfers with the flame reactions. Displacing Oxygen is a much lesser effect.
Your analysis for Ozone is also incorrect.
As some one famous said. "It should be a simple explanation but not simpler than a correct explanation"
They inject Freon into large (space bound) rockets exhaust streams to steer and make the rocket stable without giant fins that add extra weight. Plus fins cant steer in space....
It wasn't a matter of a joke, I really got read more books on chemistry. I just got my hands tied up at work again last night. My god they're pushing me. I appreciate the responses about this. I was reading a thread about freon and it just popped to think that it may have been mixed with the aluminum powder and ammonium percholate. thanks.
