1st Static test
linker33
1st Static test
Post by linker33 » Sat Nov 18, 2006 5:08 am
First static test that actually worked. I thought a night time shot might look better (and I don't have the paitence to wait till morning), but like I've heard, KNO3/Suger doesn't give a very good flame, so you can't really see very much. It did sound pretty good though. I'll try and post some daytime tests tomorrow. http://s79.photobucket.com/albums/j138/ ... ure020.flv
Greg O'Bryant
re: 1st Static test
Post by Greg O'Bryant » Sat Nov 18, 2006 3:36 pm
Congratulations! What is the size, impulse, KN etc of your engine? From what I could see it looked like it had a good start! Do you have a rocket to put it in?
Ray
re: 1st Static test
Post by Ray » Sat Nov 18, 2006 4:07 pm
It had the right sound for a sugar motor...
So share the details, like Greg ask...Interested minds want to know.
linker33
re: 1st Static test
Post by linker33 » Sat Nov 18, 2006 6:54 pm
Is thier a way to figure the KN and impluse without a pressure transducer, or a test stand? Based only off the the known propellent, and the physical specs of the motor? ie. grain size/internal motor dimensions, nozel size, ect...
Edit: Ok, I'm reading thru Nakka's theory section, so hopefully I'll have some answers shortly.
linker33
re: 1st Static test
Post by linker33 » Sun Nov 19, 2006 12:50 am
http://s79.photobucket.com/albums/j138/ ... 010011.flv
This is a daytime test. As you can see it blew the nozzle. This was the result. http://i79.photobucket.com/albums/j138/ ... 010012.jpg
Next time I'll drill and pin the nozzle to the case.
This motor was as follows...
Inside casing dia. - 10mm
Nozzle dia. - 3mm
Inside casing length - 26mm
Grain...
Length - 26mm
Outside dia. - 9mm
Core dia. - 3mm
I'm having some trouble w/ nakka's calculations to determine KN, Impluse ect... Anyone want to get me going in the right direction here, or is more info needed?
linker33
re: 1st Static test
Post by linker33 » Sat Nov 25, 2006 7:21 pm
Ok... I got tired of rolling paper tubes, and decided to go the PVC route. 1/2" PVC 600lbs. Here she is...http://i79.photobucket.com/albums/j138/ ... 0012-1.jpg
I used a socket as the nozzle. I don't think I'll have any errosion problems. You can see the socket herehttp://i79.photobucket.com/albums/j138/ ... 010017.jpg.
Ok, now don't laugh at my test stand. I wanted a test stand right away, and this is what I came up with. http://s79.photobucket.com/albums/j138/ ... stTest.flv. Not super impressive, but there's room for a larger grain. Grain was 2"x1/2Dx1/8d http://i79.photobucket.com/albums/j138/ ... 010025.jpg
After 3 tests, no nozzle errosion, and no significant leakage at the otherend. I just used alluminum foil to block the end prior to screwing the cap on.http://i79.photobucket.com/albums/j138/ ... 010002.jpg
http://i79.photobucket.com/albums/j138/ ... 010003.jpg
