A working rocket
A working rocket
Post by Mark » Sat Nov 11, 2006 4:48 pm
Kakeman
re: A working rocket
Post by Kakeman » Wed Nov 15, 2006 4:56 pm
Is that radar missile?
Home made cant be so expensive, even nearly :P im going to build one some day.
carp
Post by carp » Thu Nov 16, 2006 12:28 am
those are actually easier to build than you would think
JetSet
Post by JetSet » Thu Nov 16, 2006 3:24 am
Quick question, why are they ejected/mortar'd before the main rocket is fired?
NickC
Post by NickC » Thu Nov 16, 2006 4:44 am
i think it's called air launched or something, probably something to do with stability ?
marksteamnz
Re: re: A working rocket
Post by marksteamnz » Thu Nov 16, 2006 5:19 am
JetSet wrote:Quick question, why are they ejected/mortar'd before the main rocket is fired?
Because if it launches under full rocket power it chars the crew standing by. There are ways round this such as having the launcher and controller separated but accuracy goes down as the guidance has to compensate for a variable offset.
Standard method is an ejection charge and then full motor power, at a safe distance, then a slower burning substainer to maintian speed until impact.
Easily and cheaply knocked up in a afternoon I believe LOL
Mark Stacey
www.cncprototyping.co.nz
Kakeman
Post by Kakeman » Sat Nov 18, 2006 9:55 am
i think that there is radar transmitter under that plastic thing and it send radar waves to tank and waves reflects from it so missile can "see" target.
Jim Berquist
Post by Jim Berquist » Sun Nov 19, 2006 7:49 pm
Nickc:
Rocket is ported ! Could not launch from the tube. It is directed via the ports...Turned!!!
It shire don't wast any time firing up , does it!!!!
In the old days it would be a gimbaled engine....Porting is faster and easier, to control. Did you see the way it vectored upward on take off! Thrust was directed to the bottom ports, lifting it upwards and forwards....
On 3rd view it did look like it turned upwards.....Ports in rear end????
Fins poped out! I don't think they due any more then stablize dirrection, What do you think!!
Jim
Kakeman
Post by Kakeman » Mon Nov 20, 2006 5:06 pm
is there gyro sensor inside missile? what would be easyest and cheapest that sensor thing... err? would IR be cheap?
skyfrog
Post by skyfrog » Mon Jan 22, 2007 9:27 am
Yeah same opinion. The fume of main rcket engine explains itself. No laucher wish to be torched by that fire. Besides the launch system is protected by the ejector too.
Long live jet engine !
Horace
Jetbeetle
