anyone into hybrids ?
laffin-gas.com
:twisted:
:twisted:
Re: anyone into hybrids ?
Thanks anguz.anguz wrote:laffin-gas.com
:twisted:
I like rocket powered cars and that one's great. They are a bit confused in their history page and who is making hybrids, but over all a fun site.
re: anyone into hybrids ?
mark, what's inside of a hybrid? I understand the concept and all that, but actually machining one. the NOX regulating nozzle is just a disk with a hole in it and two o-ring groves and then you have a burst disk in front of it? or there is like a kind of nipple attachment in there where you attach the nylon tubing? do you use circlips to hold the nozzle in? it seems like it'd be kinda deep.
Nick I'm no expert but there is a yahoo group for Hybrids and a lot of developement happening as in the UK it is illegal to mix propellent with out an explosives liscence, so hybrids rule. http://groups.yahoo.com/group/hybridrocketmotors/
Join up and read up the links and files
Briefly my understanding from my Hi Power rocketry mags is the plastic fill tube on some motors is burnt thru by the ignitor so the Nitrous is released at the same time as the fuel is being exposed to the ignitor flame.
I got that part, but just wasn't sure how they were executing it. That 44.5mm motor on your site looked like a hybrid. I was just wondering if it was made up of two screw together tubes or something else.
-not even sugar propellant in the UK?
Check out this site. They have instructions on how to build a Hybrid motor of their construction...It should give you a good picture of the way a hybrid motor works.
The system they use is very common in the hybrid world. They call it a U/C valve...can't remember what the letters stand for...I know they are the first letter of the names of the two guys that came up with the idea. Seperately at the same time. I guess they both showed up at a research launch with the same thing...
great website!! explained a lot of stuff I was confused on
what is the thickness of the nitrous part of the motor? I guess what are the thicknesses of the nitrous tube for the specific OD of it?
Re: re: anyone into hybrids ?
From what I've read a definite no to sugar propellent. You have to understand the history of the UK The IRA fighting in Northern Island used all sorts of chemicals to make explosives some of which ended up in the bombing campaign on the UK mainland. One type was even called co-op because you could buy the ingredients at a local store (a cooperatively owned store hence the slang). So the Government are hot on mixing propellent and now with the Tube bombings it's not going to get better. I'm not English but I'm married to an English wife.NickC wrote:I got that part, but just wasn't sure how they were executing it. That 44.5mm motor on your site looked like a hybrid. I was just wondering if it was made up of two screw together tubes or something else.
I did forget I've also made piercing units for Micro hybrid and they use a plastic disk to seal off the Nitrous. The ignitor melts the disk and starts the burn. The piercing units I made had different size holes compared to standard as the lads thought they were not optimum in the kit
http://qwksite.com/rlmac/rene/microhybrid/tnmh.html
I believe the tubing is the same as a composite (solid) motor. The pressures are much the same, somewhat lower. They just make the tubing longer.NickC wrote:what is the thickness of the nitrous part of the motor? I guess what are the thicknesses of the nitrous tube for the specific OD of it?
From the other post...
29mm - 0.058
38mm - 0.083
54mm - 0.095
75mm - 0.115
98mm - 0.188
Combustion chamber pressure is lower than the tank pressure. I believe that nitrous will self pressurize to around 1200 psi.
Just a note, UC, Ubanski Colbourn (sp?), the 2 guys who came up with the idea at the same time.
Yep, those are the guys...thanks for the reminder.
can you buy those somewhere? or are there any plans?
virtually all of the hybrids on the market except HyperTech use this method.
West Coast Hybrids sells complete motors...
Buy from them, I know the guys. I am even working on some software for their test stand.
If I want to build my own though, where can I find these valves? or fidn plans for them? or what other types can be used?
