Sorta crappy attempt at sugar/kno3 rocket, few questions....
Zippiot
re: Sorta crappy attempt at sugar/kno3 rocket, few questions
Post by Zippiot » Fri Jul 14, 2006 4:10 am
Maybe some insultated quick fuse, like wrap it in the teflon sleeve and stick that inside of a straw.
But the rest of them are right, dont fuse a real rocket. Only use a fuse for sparklers
Re: re: Sorta crappy attempt at sugar/kno3 rocket, few quest
Post by tufty » Fri Jul 14, 2006 8:10 am
NickC wrote:i used the thick blue chinese fuse, it's pretty reliable and i left a good bit of it between me and the rocket and it was at an angle so my hand was never behind it.
So maybe you avoid getting burned in the "best" case. But what happens when your fuse runs too fast combined with a near-instantaneous CATO? You're not at a safe distance. The same thing applies for the fact you hadn't actually restrained the motor in any sane way.
marksteamnz wrote:Anyone who lights fuses to ignite rocket motors should be banned. Use a remote electric igniter, no ifs, no buts, no maybes.
Be safe. Killing or maiming yourself will only spoil it for you (and potentially for the rest of the amateur rocketeers)
Simon
