will it work?
bob000555
will it work?
Post by bob000555 » Sun May 07, 2006 9:18 pm
do you proplr think a 33% Magnesium 66% Zinc Oxide rocket will work im ondering of the zink oxide will work as an oxidiser
bob000555
re: will it work?
Post by bob000555 » Sun May 07, 2006 11:08 pm
i thini it will cuz the Mg's a,azing heat turns most things with O inthem into an ozadiser http://www.cci.ethz.ch/mainmov.html?exp ... language=1
rong movie http://www.cci.ethz.ch/mainmov.html?exp ... language=1
marksteamnz
Re: will it work?
Post by marksteamnz » Mon May 08, 2006 2:56 am
bob000555 wrote:do you proplr think a 33% Magnesium 66% Zinc Oxide rocket will work im ondering of the zink oxide will work as an oxidiser
Nope. You have not grasped what an oxidizer is. It is not a oxide.
Buy and read the books Ray recomended or the one in my sticky.
Mark Stacey
www.cncprototyping.co.nz
bob000555
re: will it work?
Post by bob000555 » Mon May 08, 2006 9:24 pm
but did u click the second link...it shows CO2 being broken down to C and O2 by the Mg ZnO would give off O at a much lower temp then CO2...im gona test a 50% 50% mix then work out the proportions
marksteamnz
Re: re: will it work?
Post by marksteamnz » Mon May 08, 2006 9:50 pm
bob000555 wrote:but did u click the second link...it shows CO2 being broken down to C and O2 by the Mg
Nope C and MgO
ZnO would give off O at a much lower temp then CO2 im going to test a 50% 50% mix then work out the proportions
You have performed Heats of reaction / heats of formation / enthalpthy change calculations?
Mark Stacey
bob000555
re: will it work?
Post by bob000555 » Mon May 08, 2006 9:59 pm
Mg powder burns a 4000*f Zinc oxide melts(hopfuly relesing O) at 1400*f as for that last caluclation i dont know waht that is...this is the first time iv used an unconventional oxidiser
i know i cant spell well...you dont need to tell me
