hello
I new to the forum but old at looking the site
my name is alexander voivoditch
I am writing here because I am experiencing weird internet behavior:
When I try to go to the page it does not work with
the dsl . I can reach it only with the 33kb modem (but cant acces the faq)
and I'd rather like to use the dsl (it's free for me)
I am also unable to write to keneth (it do not work even from the site link)
it hapen only with this site
have you any idea about this ?
best regards
Alexander
Voivoditch
new and quite lost with the site and forum with dsl
investigating the problem
thanks a lot for your answere I am still searching
it may be a problem due to the server the dsl or my provider.
anyway it work with the slow connection.
I am aparently like you interested by propulsion systems.
My own interest is aimed to the ram jet ; the pulsejet (valved or not)
and the turbine I plan to make a turbo conversion some day .I picked a big turbo on a piper arow small airplane ,it is nearly new and should be good for the goal the idea is to make a small auxiliary power unit (generator)
I am also looking to find som ways to build big pulse jet more reliable than what can be found now .
best regards
alexander
best regards
alexander
Hi Alexander
It sounds like a DNS (domain name server) addressing probelem to me, you probably have the DNS details correct for your dial up connection but incorrest for the DSL connection.
If not report the problem to your DSL provider and get them to check the address form their end to see what is happening
viv must be right
Hi Alexander
good idea !
I will do that Iam quite sure it comes from their side. It doesent happen with the first provider and only for this site and an other one
changing of subject
I have put a post in the rocket section that may interest those that are interested in the solid combustion ramjet it is a reply to someone looking for info about it in spain. I directed him to a good magazin special edition in french about the topic and all ramjet it is interesting
best regards and thank again
alexander
good idea !
changing of subject
alexander
