Thanks, this is what I really needed. I'm not so good at electric engineering, the greatest electric stuff I've ever built is merely a rectifier. I think, I shall continually treat electric stuff as blackbox for the rest of my life. hehemk wrote:A special coil-spark plug combination isn't needed. But a motorcycle coil is good. You just need a switch (or a relay if you are good in electrical stuff), a 12V (=) power supply, maybe a battery, and a ~0.22 10e-6F capacitor.
Connect the switch, the coil and the power supply to a closed "circle". Finally place the capacitor (reduces self induktion sparks in the switch) parallel to the switch.
You should get a nice spark at every switch then.
Note: A relay would do the switching process for you, maybe much faster, too.
Can't find blue shim sheets, but got strips, so...
Re: Can't find blue shim sheets, but got strips, so...
I have two pulsejet projects proceeding at the same time, one is valved which is in half way before its birth, while the other one, a valveless. Due to the best thing I can do is welding for the time being, my valveless is now under construction too : welding the body. Perhaps the valveless will be delivered first.
Here is the drawing.I wrote:A special coil-spark plug combination isn't needed. But a motorcycle coil is good. You just need a switch (or a relay if you are good in electrical stuff), a 12V (=) power supply, maybe a battery, and a ~0.22 10e-6F capacitor.
- simple_relay_ignition.jpg (15.81 KiB) Viewed 12372 times
Ignition
Hi Marten,
The relay coils in series with the ignition coil, will not allow sufficient current to flow through the coil thereby giving a very weak spark ( or none at all ). I would use a two pole relay, and isolate the ignition coil from the relay coils.
Al Belli
Al Belli
Here's an updated version.
The transitor must handle about 6 to 10 A.
The resistor sets the voltage for the relay (eventually unnecessary).
- by Marten Klein 2004
- simple_transistorized_relay_ignition.jpg (19.23 KiB) Viewed 12306 times
Hi Marten,
Good job, and thanks again.
Needs a big diode across the transistor to buck the EMF fromt he coil or the thransistor will get destroyed.mk wrote:Here's an updated version.
This circuit will end up something like the one posted on Bruce Simpson's website, I think.Viv wrote:Needs a big diode across the transistor to buck the EMF fromt he coil or the thransistor will get destroyed.
It's becoming more and more complicated.
Regarding Marten's original circuit, I have seen someone else used it too.
I'll try to find the drawings and have it posted.
EDIT : here it is.
- (119.95 KiB) Downloaded 592 times
Ooops!
Maybe a mistake in the transistorized version...
The base-collector (transistor) voltage, being at 12 V by using a 12 V relay, is a bit too high, I think.
The most simple version should be a double relay then.
Transistorized version is recommend for high spark frequenzies only.
Both capacitors are 0.22 10e-06 F.
- simple_double_relay_ignition.jpg (20.27 KiB) Viewed 12251 times
Fuel injector
Hello,
I'm Scott, and new to this forum, as you might guess :-}
I have a question about propane as a fuel, I noticed that earlier in this thread Steve posted a picture of a design with the injection going in the side, I'm thinking it's propane and looks to be 1/4 inch tube.
What's on the inside? Does the tube just end?
How are the rest of you dealing with propane injection?
And I gota tell you all, this is harder than you make it look! I've made some really spectacular torches but no running engine.
Thanks - Scott
Thanks - Scott
Fuel injection
Sorry, replied to the wrong thread :-O
Fule injection
Okay now I now why I can't get it running! I'm dumb. This is the right thread, I just never looked at the bottom!
