I tried to cast aluminum last week
Postby Johansson » Wed May 12, 2010 5:55 pm
I did an attempt to cast an aluminum block for my soon-to-be TV94 gas turbine, it was great fun even though the cast part came out less than perfect.
http://www.youtube.com/watch?v=RxDDQwhhoU4
Johansson
Re: I tried to cast aluminum last week
Postby metiz » Wed May 12, 2010 6:22 pm
Holy aluminium casting, batman!
Try a vibrating surface plate to get rid of any airbubbles when casting. Also try preheating whatever you're casting in (is that a pie shape? :mrgreen: ) so the aluminium solidifies more evenly.
Postby Johansson » Wed May 12, 2010 6:29 pm
Yup, a pie shape indeed. It will never be its old self again... :mrgreen:
Besides the things you´ve pointed out I should have guessed that the teflon coating in the pie shape would burn and cause cavities, but it was only a primary test and did indeed inspire us to make a more serious attempt later with an oil burning forge and better quality aluminum.
metiz wrote:Holy aluminium casting, batman!
Johansson
Postby hinote » Wed May 12, 2010 8:12 pm
Johansson wrote:Besides the things you´ve pointed out I should have guessed that the teflon coating in the pie shape would burn and cause cavities, but it was only a primary test and did indeed inspire us to make a more serious attempt later with an oil burning forge and better quality aluminum
Be careful
At 680°F Teflon pans release at least six toxic gases, including two carcinogens, two global pollutants, and MFA, a chemical lethal to humans at low doses. At temperatures that DuPont scientists claim are reached on stovetop drip pans (1000°F), non-stick coatings break down to a chemical warfare agent known as PFIB, and a chemical analog of the WWII nerve gas phosgene.“
hinote
Postby Johansson » Wed May 12, 2010 8:22 pm
hinote wrote:Be careful
Not bad for a frying pan! :shock:
Fortunately we were doing the casting outside on a windy day so we were more likely to suffocate from the nearby cows farting than from the teflon gasses.
Johansson
Postby tufty » Sat May 15, 2010 12:06 pm
Johansson wrote:…make a more serious attempt later with an oil burning forge…
Bet you wish you hadn't flattened that big pulsejet now, eh? Heat and vibration, all in one convenient & efficient package :)
tufty
Postby metiz » Sat May 15, 2010 12:52 pm
Rofl you read my mind :P
Postby Johansson » Sat May 15, 2010 3:15 pm
tufty wrote:Bet you wish you hadn't flattened that big pulsejet now, eh? Heat and vibration, all in one convenient & efficient package :)
If it actually ran it would have been the best heater ever, but at the time when I crunched it it wasn´t even capable of toasting bread... :mrgreen:
Johansson
Postby teresap989 » Mon Sep 06, 2010 3:11 am
The old thread was a re-incarnation of several threads killed before it.
__________________
watch free movies online
teresap989
Return to Tools and Construction
Who is online
Users browsing this forum: Google [Bot] and 1 guest
cron
