Here is a supplier of flexible stainless steel braided hoses suitable for use on pressure jets to decouple the heat exchanger coil and feed pipe thermal expansion from the supersonic nozzle, this stops misalignment problems as the engine throttles up and down.
Supersonic nozzle alignment problems can be a major cause of problems and power loss on Gluehareff pressure jet engines of all sizes but fitting a high temperature flexible stainless steel hose as above will help to solve this issue.
FLEXTECH INDUSTRIES INC web site http://flextech-ind.com/products/flexhose.shtml
Supplier "Flexible stainless braided hose"
